Replacing rims could use some help - 92 Camaro RS
Old Nov 18, 2015 | 09:33 AM
ohmslaw's Avatar
nevermind. figured it out on my own
Old Nov 18, 2015 | 11:44 AM
bamaboy0323's Avatar
Re: Replacing rims could use some help - 92 Camaro RS
Deleted
Old Nov 19, 2015 | 05:02 AM
ohmslaw's Avatar
Originally Posted by bamaboy0323
Deleted
thanks for the help?
Old Nov 19, 2015 | 06:17 AM
You're welcome :-). I deleted it because i didn't want to give you the wrong advice. You shouldn't need spacers with a that 0 offset wheel built for the camaro. You only need spacers when the wheel is not 0 offset, for example a 56mm wheel would need a 2inch or so spacer.
I'm pretty sure that our cars have a Center Bore of 70.3 so i think you would need to get hub centric rings to get them to fit perfect on the center bore.
I may be wrong but i just purchased wheels for my car and went with an 18x9.5 ET20 offset 5x114.3 bolt pattern. I ordered 1" adapters for mine but i had to because of the different bolt pattern. Hopefully this helps
Raz
Feb 4, 2009 08:53 PM
badassz4jc
Mid-West Region
Jul 6, 2008 10:51 PM
ShaneBuss
Sep 11, 2000 02:30 PM
