Drag Wheel setups with a 4th Gen rearend
Old Mar 23, 2016 | 06:52 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Well I'm looking at picking up a drag pack for my car this year, so I can have a bit more fun on the 1/4mile. For the fronts i've decided i'm going to go after the GTO aluminum Spares for front runners (new tires obv). But I need suggestions from those on what you've used with your cars if you have a 4th gen rear end since they stick out 1-1.5" further out on both sides. I dont want to pick up a pair of wheels for the back then find out they wont fit once i put a tire on w/ the 1/4 panel lip
Old Mar 23, 2016 | 07:12 PM
Slash's Avatar
Re: Drag Wheel setups with a 4th Gen rearend
Also in mind the car has been lowered with the Eibach Pro-Kit Springs. and also has KONI Yellow shocks, the Founder's Performance rear adj suspension, and Spohn Adj Torque Arm with K member mount
Old Mar 23, 2016 | 09:33 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Any 4thgen offset rear wheel would fit fine, you can use a bolt on spacer in the front if you use a set of 4thgen wheels. I bought a set of six polished ZR1 wheels from a buddy with an 01 Z28. I got four 17x9.5 with some Z rated street tires and 2 17x11's with 315/35R17 Nitto 555R drag radials. Sorry I don't have any pics yet, I've only had the wheels a couple weeks and the car is still on stands for winter. Wheels are from OEwheelsllc.com.
Old Mar 23, 2016 | 09:36 PM
Slash's Avatar
right now i run a set of c5 z06 wheels. but they're quite heavy 17x9.5s up front and 18x10.5s in back, Reason I was gonna run the GTO Spares for front runners and then i needed something for in back for a taller tire and that'll still clear the ls1 brakes
teddy61
Jan 12, 2026 07:30 PM
oblivion
Exterior Parts Wanted
Apr 18, 2016 10:22 PM
hotrodjames
Mar 23, 2016 02:05 PM
Bullydawg
Wheels and Tires
Feb 29, 2016 07:59 AM
vetteman9368
Jul 8, 2003 12:15 PM
