Adapter torque specs?
Old May 5, 2016 | 06:37 AM
sahlomonic's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 2:73
When mounting 2" adapters for 4th gen wheels, I have two questions:
1) How many ft/lbs are needed for the adapters to mount to the hub?
2) How many ft/lbs are needed for the wheels to mount to the adapters?
Currently I have everything at 80 ft/lbs. Is that the right torque spec? Honestly this is the first time I have used a torque wrench to mount wheels, and when I've done it 'by hand' in the past I feel that I've always torqued the wheels down a lot more.
Old May 5, 2016 | 08:51 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Adapter torque specs?
I believe the range is 90-120. I use 100 ft/lbs.
pfreer3
25
Aug 12, 2016 12:28 PM
brodysZ28
May 31, 2016 02:39 PM
MarkF
May 28, 2016 09:45 AM
neilcase
Interior Parts Wanted
Apr 10, 2016 05:31 PM
jjjosh
Apr 7, 2016 10:38 AM
