Removing IROC center caps.
Old Aug 15, 2016 | 09:17 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
So i recently lost a center cap IROC emblem on my 1988. Just the emblem came off, it seems to be glued on. I see the replacement center caps are available off EBAY. But how do you get the caps off? Can you just replace the emblem? Seems like if you pry them off with a screwdriver, you will wreck them. What about taking the wheel off, to get the caps off?
Old Aug 15, 2016 | 09:32 PM
GASPEDDLER's Avatar
Re: Removing IROC center caps.
I've used a very small flathead screwdriver to remove them after the decal wears away.
Old Aug 15, 2016 | 09:49 PM
gt4373's Avatar
Transmission: 5-Speed Manual
You Could Try This.
Old Aug 16, 2016 | 08:42 PM
Car: 1988 IROC-Z
Wow.....that is genius material! will have to try it for sure....since my decal is gone, dont really care what happens to the old one!
Old Aug 16, 2016 | 08:47 PM
GASPEDDLER's Avatar
Exactly
Old Aug 16, 2016 | 08:55 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I just use a small standard screw driver with a really thin tip.
Old Aug 17, 2016 | 08:06 PM
Car: 1988 IROC-Z
Well i got the cap off, but the velcro trick did not work. I think it just stuck to the old glue, and pulled some of that off. Didnt feel like cleaning off the glue, so i just used a small screwdriver, and pryed it off. Ordered a new cap off Ebay.
MadGrunt
Wheels and Tires
May 28, 2017 10:11 PM
EDGE
May 19, 2016 10:26 PM
Yoda_the_Green
Apr 21, 2016 01:39 PM
madness
Apr 9, 2016 08:03 PM
erik69&85
Apr 3, 2016 01:33 PM
