18x9.5 back spacing info
Old Jan 23, 2017 | 11:34 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
did a bit of searching, found all sorts of info, one says 5.5, one says 6.5, and just about everything in between.
91 GTA, stock suspension, but will be lowered. Not afraid to modify inner fender wells.--want 9.5 on all 4 corners, same tires if possible for easy rotation. daily driver, no track time, stock axle width.
don't want to stick out of fenders.
thank you for any info, or pointing me in the right direction.
Old Jan 23, 2017 | 03:25 PM
Beater79TA's Avatar
Re: 18x9.5 back spacing info
We did 18x10.5 on all 4 corners. 6 inch backspacing in front. 6.5 inch in the rear. Not sure this helps you though since you want to use a narrower wheel.
Old Jan 23, 2017 | 08:59 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
5.25" for flush with fender, a bit more to tuck in in a bit.
Old Jan 24, 2017 | 09:15 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Think you got a typo in there. Did you mean 6.25"?
To the OP, when you're playing with such wide wheels and tires you really need to measure out clearances on your car. There isn't any room for error and things have to be dead nuts on. Better to be a little too much backspacing and have to apply a small spacer than to be too little backspacing and poke out too far.
Old Jan 24, 2017 | 12:59 PM
paul_huryk's Avatar
Nope, 5.25" brings the wheels flush on all 4 corners in 18" x 9.5". This of course assumes one is running a 3rd gen rear.
Old Jan 24, 2017 | 11:18 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Oh, I see, somehow I got 10.5" wide on my mind, probably from Beater's post. Didn't notice the OP was asking about 9.5"
Old Jan 26, 2017 | 05:35 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
outstanding, thanks guys. There are soooooo many threads and info out there, and it all says something different.
Thanks again!
Old Jan 27, 2017 | 05:44 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I have 18x 9.5 all 4 corners and 2in drop all 4. I have 6in back spacing with no rubbing. The tires are just inside the fenders. Will not scrape on dips
Old Jan 28, 2017 | 08:34 AM
paul_huryk's Avatar
Indeed there is.
But there is only a narrow range of BS numbers that make that size wheel for a 3rd gen. From 5.25" to around 6" is the range.
Thanks again!
Old Jan 28, 2017 | 11:56 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
what size tire are you running? and can you post a side pic of your car?
Old Jan 28, 2017 | 06:04 PM
VincentZ28's Avatar
275/35/18 Front, 285/35/18 Rear
Old Jan 30, 2017 | 08:05 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Thats a real nice look.
Any modifications to the bump stops or wheel wells?
Old Jan 30, 2017 | 11:51 AM
VincentZ28's Avatar
No
Old Jan 30, 2017 | 04:53 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Nice delivery of example pics, Vincent.
Old Mar 19, 2017 | 08:28 PM
maroboytrell's Avatar
Car: 92 RS VERT♡86 Z28♡88 GT
Engine: 305 Lm7 ???
Transmission: 700R4 T56 ???
Axle/Gears: 86' Z28 4:10...92' RS 3:42
Do you think a 10.5 or 11 inch rear wheel would fit with the same BS?
Old Apr 27, 2017 | 09:05 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Mine are 18 x 9.5 on rear with 6"BS and 1/2" spacers. (so 5.5 net BS) Without the spacer it fit but I thought the tire sat inboard too much.
Fronts are 18 x 8.5 but I don't recall the BS.
Old Apr 27, 2017 | 09:10 AM
Beater79TA's Avatar
10.5 fit with 6 inch backspace on the front and 6.5 on the rear. With a 315 tire they are flush with the outside edge of the fender. It will also require some clearancing within the wheel wells.
Old Apr 29, 2017 | 04:57 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
is that 6inch BS on all 4 rims? and did you use any spacers? ty those wheels look great
Old Jul 15, 2017 | 01:43 AM
jonmcintyre's Avatar
would rolling the finders do enough for that? I wanna run 18x10s out back an wanna see if I can get a 315 on it
Old Jul 16, 2017 | 02:02 PM
Beater79TA's Avatar
I doubt it. You can try but I expect you'll need to trim some of the sheetmetal inside the wheel wells on both ends.
Old Jul 16, 2017 | 08:36 PM
twinturrbo406's Avatar
Car: 1987 Pontiac GTA
Transmission: Haven't decided yet ;)
... that looks fantastic !!! ..
Old Jul 29, 2017 | 03:59 PM
Watford91Z28's Avatar
Car: 1991 Z28
Engine: 6.0
Transmission: t56
Axle/Gears: 3.73 posi
Did you have to do any trimming in the front with your 10.5s? I test fitted some US Mags 9.5s on the front with a 275/40R18 and have clearance issues when I went to turn. It would hit the ground effects on the lower part of the front bumper cover and the back of the wheel well.
Backspacing=5.25in
Old Jul 29, 2017 | 08:07 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
photo bucket sucks....
Old Jul 29, 2017 | 08:18 PM
tom86iroc's Avatar
Car: 1986 iroc
yeah they changed their site around now
Old Jul 30, 2017 | 11:26 PM
VincentZ28's Avatar
Backspacing=5.25in
If you change the tire size to 275/35/18, you will have clearance. Look at the front of my car. No issues
Old Oct 28, 2017 | 11:45 AM
tom86iroc's Avatar
Car: 1986 iroc
is that 6 inch bs on all 4 wheels ? thanks
Old Oct 28, 2017 | 04:16 PM
your not tryn...lol
Old Oct 29, 2017 | 06:30 AM
VincentZ28's Avatar
Yes!
Old Nov 19, 2020 | 06:26 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
such a great thread !
