225-55-16 tires on 9 inch rim?
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Has anybody put 225-55-16 tires on 9 inch rim?
Currently I have 225-55-16 on 8 inch rim at front and 245-50-16 on 9 inch rim at rear, but here in Japan it's impossible to find 245-50-16 any more.
So I'm thinking about putting 225-55-16 at rear too.
Car: 1984 Trans AM
Transmission: 700-4r
Re: 225-55-16 tires on 9 inch rim?
U certainly would mot drive these low, low profile tires in my city. potholes, pavement crack & just plain rough roads would destroy the tires & rims & suspension! Besides they look like crap.
on a 9 inch wheel, you could technically go wider if there is something available... up to a 275 or so.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Those tires are the same profile as the stock 245/50-16, only not as wide.
A 9-inch rim is really too wide for a 225, but people run 'em.
8 inches would be more appropriate...
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Go wider if you can. 225 is way to stretched for a 9" rim. Check out the spec sheets of the tires you are considering. They will give you an acceptable width range for their tires. No two manufacturers will be the same.
Dmity Kiev
Dec 26, 2008 06:55 AM
