16" to 17"?
Car: 91 Z28 Coupe
16" to 17"?
So I have finally pulled the trigger, going from stock 16" (235 55R16) to 17" (17x9 '02 35th wheels). Will 275 40r17s be the best fit for overall fitment, and speedo accuracy? Any input would be appreciated.
Thanks, as always
Thanks, as always
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: 16" to 17"?
275-40-17 is the correct size - no need to correct the speedo.
You need about 5" of BS with those wheels, so take the wheel BS, subtract 5" and that is the spacer thickness you need.
Car: 91 Z28 Coupe
Re: 16" to 17"?
Thank as always.
Paul, love your wheels BTW.. Just wish they were closer to stock. Very close to you, Bridgewater..
Re: 16" to 17"?
Thank you.
Unfortunately stock style wheels are flawed when it comes to weight vs. brake clearance vs. weight vs. cost - so we went with something more accommodating.
