Grabbed some Corvette 19x10 & 18x8.5 wheels
Old May 15, 2017 | 07:19 PM
GoStumpy's Avatar
I couldn't resist! They are chrome, but look just like these:
19x10 rear
18x8.5 front
I am wondering if anyone on here is running the same size (I am pretty confident a few of you are!) and what size tire you are running, whether you're happy with it, or wish you went with a wider/narrower tire?
Also, I am running stock rear end in my 85 Camaro, so I'll need spacers all around. I am going to mock up the wheel and measure to see what size spacer I want, I've heard 2" and 2.5" but let me know what you're running!
I'm STOKED!
Old May 15, 2017 | 08:07 PM
GoStumpy's Avatar
Re: Grabbed some Corvette 19x10 & 18x8.5 wheels
Looking closer they are "Made in China" so I would assume that means aftermarket/knockoff rims... oh well thought the price was too good to be true! (Paid $145usd for the set)
I am looking at tires, and I think Firestone Firehawk Indy 500 is my choice... the lowest price high performance tires I can find, especially up here in canuckistan.
From what I've read and researched I think
285/35/19 rear
255/40/18 front
My only dilemma is 285 or 275 for the rear.....
Old May 16, 2017 | 10:33 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Personally, I would budget a few more $ for better tires - you already have a great deal on the wheels.
Tire size looks good for the wheels.
Old May 16, 2017 | 11:14 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I run the exact same rims except they are GM wheels. I love them, love the look. You will need wheel spacers for these. I have 1.5' front and 2' rear on mine. The tire size you listed should work but check the clearance as I have 275's in the rear. 285's were on the car when I bought it and it rubbed the inner well when cornering under load. I have 245's on the front. I agree with the OP and don't cheap on the tires. I put these Cooper Zeon's on and I really like them and the cost was reasonable.
Old May 16, 2017 | 06:37 PM
GoStumpy's Avatar
They might not be able to get the size I want in the Indy500, so he's going to call me tomorrow with some options...
From everything I read though the Indy500 is a good high performance tire, no reason to say it's "cheaping out"... maybe if this was my year round daily driver or something but it's just a nice weather cruiser
Attached Thumbnails Grabbed some Corvette 19x10 & 18x8.5 wheels-img_7612.jpg
Old May 17, 2017 | 07:12 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
A 285/35 is a good size. It will keep sidewall similar in height to the fronts. Could even go 245/40 fronts for better match.
285/35 may require some heavy inner wheel well work with hammer to clear. May need 2.5" spacers on rear to get it to clear if 79 mm offset
Old May 21, 2017 | 09:12 AM
Citation X's Avatar
Car: 92 RS
I have the oewheels 19x10 on the rear with 285/35 and had some fender lip rubbing with 2.5 spacers. Had to do some inner fender massaging as well. I just got some 2 inch and had to do more massaging plus take off the bump stops and grind the back side of them a bit to clear. Have yet to drive it to see if I need to massage more.
I also just put on a adj. panhard. So if the 2 inch won't work with some massaging I will try the 2.5's with the new panhard as the fender lip was only rubbing 1 side.
Old May 26, 2017 | 09:39 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
That a hell of a deal for one of the best looking vette wheels imo.
