c6 19x10 with 4thgen rear question
I searched but unfortunately the search engine won't pick up on c6.
I drove this car with these wheels, a 3rdgen rear and spacers and it worked, I can't remember what size spacer, iirc 2.25 ill check tomm.
The 19x10 have 285/35/19 tires. I now have a 4thgen rear in the car, Im redoing a lot of stuff and haven't played around with it much or put it on the ground (fully adjustable rear suspension now, haven't yet adjusted).
Should this combo of the 4thgen rear and this tire/wheel size clear without spacers? I already had to bfh it in a little with my previous setup.
kyle
kyle
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: c6 19x10 with 4thgen rear question
I run mine with a 5/16" spacer with 295/30 and 305/35. Veryy tight inside but with hammer work it clears
Car: 89 Iroc-z
Transmission: TH400
It was custom made hubcentric slip on by skulte back when they were in business selling spacers
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I run the same wheels with a 4th gen rear. I have a 1" spacer just because I like how it sits in the well. One of those slip-on spacers is all you really need.
