New IROC wheel from 6LE. What size to make it?
Old Jan 29, 2018 | 10:02 AM
  #101
Abubaca's Avatar
Re: New IROC wheel from 6LE. What size to make it?
That wheel in your pic is missing the trim cup/center cap. It's supposed to fit that way.
Old Jan 29, 2018 | 10:06 AM
  #102
Abubaca's Avatar
Like this. ...but not exactly these of course.
Old Jan 29, 2018 | 10:11 AM
  #103
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
The wheel wont go on the rest of the way cause its hitting the strut but it would have pushed the center cap off.
Old Jan 29, 2018 | 10:19 AM
  #104
Abubaca's Avatar
Well until they're in our hands, I can't guarantee anything. Maybe they won't fit. That would suck.
But I'm not worried about it.
Old Jan 29, 2018 | 11:06 AM
  #105
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Hope he don't ship out wheels that don't fit that would be a waste of time and money for everyone. I just bought a cts-v front brake upgrade and sold my 4th gen rear and bought a 8.8 thirdgen width if these wheels don't work I'm screwed out of a lot of extra money.
Old Jan 29, 2018 | 11:13 AM
  #106
Abubaca's Avatar
The 8.8 at Thirdgen width is what I would've ordered. That's the rigth width for these wheels.
The CTS-v brakes should fit. I know 6LE designed the clearance around all the modern aftermarket kits, but not necessarily around GM kits because computer blueprints of the kits aren't readily available. ...still the CTS v brakes should fit. As with any retrofit kit like that though, anything is possible.
Old Jan 31, 2018 | 08:09 AM
  #107
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Ok I heard back from Mark on this sounds like he was aware of this issue from the go this is what he said.....We 3D modeled our HUBs off of original IROC wheels (meaning the center part and lugs is identical) so it definitely won’t have the issue shown in the pic. Won’t have pics of them on a car for about 3 weeks though. Thanks!
Old Jan 31, 2018 | 09:40 AM
  #108
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Unfortunately without actual verification (production wheel over the actual brake kit), one can never be sure of clearance just by using CAD data or even good old math. CTS-V brake are some of the largest you can buy and are larger than even the C6 Z06 system.
Old Jan 31, 2018 | 10:25 AM
  #109
Abubaca's Avatar
Any sort of time update? Will HE have pics in 3 weeks or does he expect them in customer's hands in 3 weeks?
Yeah that certainly makes sense. When he and I discussed brake kits, he just told me that they had gone over "most" all of the current aftermarket kits, and designed them to work, BUT, like all things "hot rodding" using adapted GM kits wasn't a guarantee due to not having CAD files for design.
-to dig deeper into the grey, kinda where I was going with all that was simply that when purchasing wheels, if the wheel/hub physically didn't fit on the car, I'd be pretty darn pissed. If my adapted LS1 brakes didn't fit, I wouldn't hold 6LE personally responsible. (although I'm not worried) They couldn't possible know all the various custom brake set ups out there. The shear number of aftermarket parts that don't play nice with other aftermarket parts on my car is staggering. It's a constant battle!
Old Jan 31, 2018 | 11:15 AM
  #110
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
I'm not sure when we will see them all I heard was he got the wheels on Monday.
Old Jan 31, 2018 | 01:20 PM
  #111
paul_huryk's Avatar
If they got the center bore and bolt pattern, it should bolt up if there is no other interference present by default.
You can have brake barrel to outside of the caliper interference - which is just hitting the limit of what can fit inside a particular wheel barrel - for example trying to get a 14" brake kit under a 16" wheel.
The biggest problem is the caliper face to rear of wheel spoke interference, which happens a lot - Hawk's 17" GTA wheels come to mind (and there is no excuse for the poor design) and the Ronal 17" Firehawks (which were designed in 1990 or sometime well before BBKs were common). That is only due to the pad height being too low, but spacers can only solve so much.
I've had 2 customers with 13" 4 piston brake kits buy our wheels due to not fitting with the Ronals in the past. Both jumped before doing the research to show they wouldn't fit.
Of course, the research is key - new combinations sometimes need to be thoroughly flushed out before making the plunge.
Ls1 kit is going to fit.
A-to dig deeper into the grey, kinda where I was going with all that was simply that when purchasing wheels, if the wheel/hub physically didn't fit on the car, I'd be pretty darn pissed. If my adapted LS1 brakes didn't fit, I wouldn't hold 6LE personally responsible. (although I'm not worried) They couldn't possible know all the various custom brake set ups out there. The shear number of aftermarket parts that don't play nice with other aftermarket parts on my car is staggering. It's a constant battle!
Old Feb 2, 2018 | 03:34 PM
  #112
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
I'm thinking he will have pics in 3 weeks be nice if there ready to ship by the end of the month. Have to send back my brake lines to Ed not sure what I got but there not thirdgen brembo lines. I would like to hear some tire choices for these new wheels but I'm pretty set on something sticky on all 4s
Old Feb 4, 2018 | 09:10 AM
  #113
Abubaca's Avatar
I'm looking at Continental Extreme Contact DW. 275/35/18
Old Feb 4, 2018 | 10:58 AM
  #114
paul_huryk's Avatar
Excellent tires - have a set in 275-40-17. They are very lightweight (compared to other tires in the same size), good in the rain, and ride well.
Old Feb 4, 2018 | 03:29 PM
  #115
Abubaca's Avatar
Kinda stumbled on them actually. Wasn't really looking at Continental, but kept seeing them come up in reviews, -all positive. Price was right too, and they don't look silly like some the new-fangle supercar tread patterns. Do NOT like non traditional looking tires. Ironically, these are similar to some of the higher end Michelin's, which you could argue are the best.
Turns out I have two buddies running them on their performance DD's too, and I didn't even know it. They both love 'em too.
Old Feb 5, 2018 | 08:10 PM
  #116
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
The wife said I could buy them (miracles do happen ) so I put the order in tonight before she changes her mind. I don't think she knows this doesn't include tires, or how much those tires will cost.
Of course, I know what she wants... she wants a new kitchen floor. I think that could be a fair trade .
Old Feb 6, 2018 | 12:21 PM
  #117
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
What's Marks e-mail? I tried call multiple times without luck. Also filled out the online contact form a couple weeks ago.
Anyone recieve their rims yet?
Old Feb 6, 2018 | 02:02 PM
  #118
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
No he hasn't shipped them yet.
mark@6LEdesigns.com
Old Feb 6, 2018 | 05:58 PM
  #119
krayende's Avatar
Car: 1987 IROC
Engine: LS2
Axle/Gears: BW 9 Bolt 3.27
I was one of the first to order, and I'm still waiting for the rendering of the wheel finish we had discussed. Mark seems to be very busy, haven't heard back from him. Good thing I'm rebuilding every nut and bolt of my car after paint to distract me....
Old Feb 6, 2018 | 09:15 PM
  #120
Sgt405k9's Avatar
Car: 1984 Chevy Camaro Z28 HO
Engine: 305 HO
Transmission: 5speed. (700)
What finish are y’all getting? I have a black/gold 84 z28 with the gold rims and Mark said he could get the same gold/bronze finish on these new rims. Ordered mine Friday.
Old Feb 7, 2018 | 04:11 AM
  #121
Lurbie's Avatar
Car: 89 Camaro
I stuck with the grey inserts and barrel, similar to the oem IROC wheels I have now.
Old Feb 7, 2018 | 08:23 AM
  #122
Abubaca's Avatar
Gold here too.
Old Feb 9, 2018 | 12:09 AM
  #123
thunder57's Avatar
Car: 1987 IROC
For the people that put an order in recently, did you get it at the $1280 price?
This is what mark said about running the 4th gen rear:
Hey Jake! That’s no problem, I just use 3rd gen fronts and 4thgen rears on cars like yours. I attached a pic of the actual rim for you (this finish is all black with machined face on the spokes). If you want a set, order the 3rd gen wheels but put in the NOTE at check out, 4th Gen rears. Thanks Jake!
Old Feb 9, 2018 | 04:23 AM
  #124
Lurbie's Avatar
Car: 89 Camaro
Yes, the LETHAL30 coupon code still works as of this morning. I originally contacted them through Facebook to ask how long the 30% off would run, because I don't get my bonus check until March. They replied the next day that they could get me a discount, but couldn't ensure it would be a 30% one. I went ahead and ordered them, because the small amount of interest will cost me less than missing a 30% off deal. I'm curious of 2 things: If you emailed them, how long did it take to get a reply? And was the photo he gave much different from the renderings on the site? If so, would you post it here for others to see?
Old Feb 9, 2018 | 09:58 AM
  #125
thunder57's Avatar
Car: 1987 IROC
Took him about a week to get back to me. And shorter response time after.
Attached Thumbnails New IROC wheel from 6LE. What size to make it?-eyjfcmfpbhmionsibwvzc2fnzsi6ikjbaddcem9rwvhwmgixoxzjbwxsym5svu9ndhlawe5wzw1wsklnmdjprfi0tmpbd1b.jpeg   New IROC wheel from 6LE. What size to make it?-iroc_machined-milling_2-2.jpeg   New IROC wheel from 6LE. What size to make it?-iroc_machined-milling_1-2.jpeg
Old Feb 9, 2018 | 12:07 PM
  #126
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
That's the 10.5 4th gen rears right? I cant wait to see some real pics of them on the cars.
Old Feb 11, 2018 | 04:42 AM
  #127
thunder57's Avatar
Car: 1987 IROC
10.5" rears are correct for the 4th gen. Not sure what the picture is.
Old Feb 18, 2018 | 04:13 AM
  #128
Lurbie's Avatar
Car: 89 Camaro
It looks like they're making progress. The site now says
UPDATE: These wheels are in manufacturing and will arrive Mid April 2018.
I just hope that they send the rendering soon. While I specified that I want it to look like what the website illustrates in the photos “IROC Factory size 1” and “IROC Factory Size 2” (which have a polished lip) I didn't specifically call out the polished lip.
Has anyone received their rendering photo yet?
Old Feb 18, 2018 | 05:15 AM
  #129
krayende's Avatar
Car: 1987 IROC
Engine: LS2
Mark told me the person doing the rendering was in the hospital for some time, and that he was hoping to finish the renderings this weekend.
Old Feb 18, 2018 | 08:06 AM
  #130
Lurbie's Avatar
Car: 89 Camaro
Oh no, that's horrible. I hope they recover soon.
Old Feb 28, 2018 | 06:12 AM
  #131
Lurbie's Avatar
Car: 89 Camaro
For those of us that have our orders in place, be sure to check your email this morning. Great communication by Mark, and new hope for why we haven't seen our wheels yet and when we will.
Old Feb 28, 2018 | 07:32 AM
  #132
Abubaca's Avatar
Yep, just finished reading it. Long story short, for those not in the loop, there were some legal issues regarding the name IROC-Z, which 6LE has the rights to. 6LE was in the right, and legal issues have been cleared up and things are moving forward.
Old Feb 28, 2018 | 07:54 AM
  #133
Lurbie's Avatar
Car: 89 Camaro
Looks like Mark put a similar update on the 6LE Facebook page if anyone wants more detail on their legal battle. Those with orders will want to read their email.
Old Feb 28, 2018 | 11:13 AM
  #134
thunder57's Avatar
Car: 1987 IROC
Anyone care to share their rendering. Still haven't heard anything back about mine.
Old Feb 28, 2018 | 03:50 PM
  #135
Abubaca's Avatar
I'd like to see some too. I know he said (implied anyhow) that he was behind, and his guy had been in the hospital. Drama, lol.
FWIW, I've got the one I did on page 1. ....but you know....gold!
Old Mar 5, 2018 | 08:22 PM
  #136
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
At this point I'm willing to pay just to see these wheels mounted on a third gen lol
Old Mar 12, 2018 | 11:31 AM
  #137
Lurbie's Avatar
Car: 89 Camaro
I got an email from Mark on 3/8 in response to me sending a reply to his legal battles update email saying that I still wanted the wheels and rendering. His response was asking me to send a photo of the car (I did when I ordered them, but whatever) so I sent him the photo again, and continue to wait for my a rendering. However my order seems to be in the second batch, so there are plenty of people in front of me. Has anyone else seen renderings (or their wheels) yet? I'd like to think the early orders would be getting filled by now.
Old Mar 12, 2018 | 12:40 PM
  #138
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Everyone I have talked to hasn't seen a rendering. Seems Mark has a health issue going on now but the wheels are on schedule from what there saying.
Old Mar 12, 2018 | 01:02 PM
  #139
krayende's Avatar
Car: 1987 IROC
Engine: LS2
No change in status for me, I was one of the first to pay the day they went on the website for sale (At first the link would not let us purchase...). Despite multiple emails to Mark and Kris (renderer), I have not received anything back. I understand the legal battles over the Iroc name, but I fail to see why after 3 months I haven’t been able to select a wheel finish. It’s extremely frustrating, but I do think Mark is a good guy and will work with us all. I hope this isn’t just wishful thinking....
Old Mar 12, 2018 | 02:33 PM
  #140
Abubaca's Avatar
I got an email from Mark Thursday, requesting that I send a photo...for the third time. -and I may have been the first one to pay. Regardless, it was certainly the first day.
....from everything I've seen and read on multiple forums, this seems to be par for the course when dealing with 6LE on new parts. Is it Mark, or the nature of the business, I don't know. I know I'm a little frustrated, but time and time again, Mark brings products that don't exist anywhere, finds places to get 'em made, and then brings them to market. ...so for now, I'm being patient.
Old Mar 12, 2018 | 03:16 PM
  #141
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Ok who wins the first to order prize? What time does your email for your order show? lol
Old Mar 12, 2018 | 03:48 PM
  #142
Abubaca's Avatar
I have an Email to Mark on 11/26 at 10am eastern saying ....it won't take my money!
....actual order was placed at 4pm eastern.
Old Mar 13, 2018 | 09:36 AM
  #143
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Yea got my order in after just after 4pm. Got my tires on order had to go cheap went way over budget on my 8.8 build lol
Old Mar 13, 2018 | 09:49 AM
  #144
Lurbie's Avatar
Car: 89 Camaro
I saw similar stuff, but complaints usually stemmed around delays, not really any on product quality. Plus they've been around for several years, and his Facebook page seems to indicate he'll do refunds when requested. That along with knowing PayPal will support a claim up to 6 months afterward gave me enough confidence to be patient for now.
I've bought my new tires during Discount Tire's last sale, so I've got them sitting in the basement until the wheels arrive.
Old Mar 13, 2018 | 10:58 AM
  #145
SteelDirigible's Avatar
Car: 84 Berlinetta
Engine: LR4
Can't wait to see some pics of these on the car.
Old Mar 14, 2018 | 02:48 PM
  #146
Abubaca's Avatar
SteelDirigible
-awesome name!
....as for tire, ehhhhhh gonna be a little while. I'm smack dab in the middle of painting the car and while I got a good deal on the project.....the little things are eating me up. For instance....new windshield. Might as well do it now, right? Anyhow....gotta dig up the funds for some tires!
Old Mar 23, 2018 | 12:58 PM
  #147
Lurbie's Avatar
Car: 89 Camaro
Has anyone gotten a rendering of their car with these wheels yet?
Has anyone gotten a response from, or an inside scoop with, Mark that might give us an update on when we might see renderings and wheels shipping?
I'm still being patient on the wheels because he made it clear that orders after Jan won't see wheels until mid-April, but if that's true I was really hoping to see my rendering photos by now.
Old Mar 23, 2018 | 01:44 PM
  #148
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
One guy I talk to cancelled his order. I sent a facebook message no response and email yesterday no response. From what I'm seeing no one is hearing anything and there is a lot of unhappy people.
Old Mar 23, 2018 | 02:41 PM
  #149
Abubaca's Avatar
My car is about done at the body shop. Gettin it all ready for Spring cruisin. Haven't heard anything and admittedly starting to get frustrated.
Old Mar 23, 2018 | 02:52 PM
  #150
Abubaca's Avatar
Just sent this to Mark:
Mark, and word? .....excitement over on TGO is starting to turn to skepticism. Everyone seems pretty understanding, but it's just that no one has really heard anything.
Do you have an estimated/ballpark ship date?
Thanks,
Chris
