Weld Prostar 15 x 9
Old Mar 21, 2018 | 05:17 PM
83cfz's Avatar
Car: 1983 Z28
Engine: 305 Crossfire
Transmission: TH700R4
Axle/Gears: 2.79
Weld Prostar 15 x 9
I have a 1983 Z28 & looking at Weld Prostar 15 x 9's with 5.5" backspace & 275/60 R15's. I don't want to modify wheel wells. Does anybody have this combination? Any Pics?
Old Mar 22, 2018 | 01:26 PM
onebdgti's Avatar
Re: Weld Prostar 15 x 9
Should be able to fit a 15x10 on the back with 5.5 backspacing. I am not 100% sure but I think it will fit.
Old Mar 23, 2018 | 12:10 AM
NoEmissions84TA's Avatar
If this helps you, then I have 275/60 R15's on the stock 20 slot rims on my 84 TA. IIRC, those rims are 15x8.
I believe those rims have 5.5" backspacing, not completely sure. But the right tire rubbed on the inside when accelerating around a RH turn. I fixed that by using 3/4" wheel spacers with longer wheel studs on both sides.
Old Mar 24, 2018 | 06:45 AM
83cfz's Avatar
Car: 1983 Z28
Axle/Gears: 2.79
Thanks to both for your reply. I am looking to put the 15 x 9 Prostars on the rear, with 15 x 5 Prostars on the front. NoEmissions, I assume the rubbing you had was on the front, am I correct? I see you have a 10 bolt rear with the Auburn Posi. Is that the original 10 bolt rear (I believe 7 1/2")? I am looking at a Moser 12 bolt for my car, but very expensive. I also looked at beefing up the original 10 bolt, but have heard different opinions on doing that. I plan on changing the 305 to a 350.
Old Mar 24, 2018 | 10:01 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Don't put money into the 10 bolt. It's just not worth it.
Cheapest way to go is still a Moser 9" housing and axle package and a junkyard center chunk
Old Mar 24, 2018 | 06:20 PM
Correct, 7.5" 10 bolt stock rear. My rubbing was on the inside of the rear tires, probably towards the front. If I got on it in a RH turn, when the trans upshifted into 2nd, I got a "bark" from the PASS rear 275/60/15 TA radial rubbing on the inside wheel well. I made 3/4" aluminum spacers for both rear wheels with longer studs. Problem solved.
How much power are you planning to make that you NEED the 12 bolt?
Rickj350RS
Brakes
Sep 20, 2005 08:16 AM
Larry Dunlap
Jun 5, 2004 07:56 AM
