Will 1LE brake fit behind a 3.5" Weld Prostar?
Old Sep 14, 2005 | 08:25 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
I want to upgrade to 1LE brakes up front, but I want to make sure that they will fit behind a 3.5" Weld Prostar. I run the car at the track frequently, so this would be very unfortunate if they do not fit. Let me know what you guys think. Thanks
Old Sep 15, 2005 | 07:19 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
I was also thinking that if they do not fit maybe i could make or buy a spacer. I have a lot of room in that wheel well where i could move the whole skinny out 1/4 or 1/2 inch. I guess whatever it takes to make it fit. From what I hear, the rotor and caliper should fit inside a 15" rim. I don't see why this wouldn't solve a clearance problem. Let me know what you guys think.
Old Sep 15, 2005 | 07:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Depending on backspacing they should fit.
Ed
Old Sep 16, 2005 | 11:10 AM
Rickj350RS's Avatar
Car: '90 Camaro RS
Using a spacer would be ok if they rubbed right? My thoughts are that the front end doesn't experience loads of torque like the rears and people are putting spacers on the rears all of the time. I don't think it would even have to be that big of a spacer anyway. The only thing that sticks out farther would be the caliper, right?
Old Sep 16, 2005 | 02:32 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
My 1LE setup fits perfectly behind 3.5" Center Line Auto Drags.
Old Sep 17, 2005 | 11:39 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
What is the backspacing on your rim? If it is the same, then I'm good.
Old Sep 18, 2005 | 03:07 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Size: 15 x 3-1/2''
Rear Spacing: 1-5/8''
Bolt Circle: 5 x 4-3/4''
Old Sep 19, 2005 | 09:10 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
I'll have to check to see what my backspacing is, but I had a question. When you modify the spindles for the 1LE conversion, I understand that the dust shield is removed. My question is do you leave it off permanently?
Old Sep 20, 2005 | 08:16 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I left mine off.Been that way for 4 years now.0 problems.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
overdriv
Aug 20, 2015 03:52 PM
