Will these fit my camaro?
Old Sep 16, 2018 | 08:12 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Not fluent with wheel sizes like offset and backspacing. Would these fit my car? I have a 4th gen rear but plan on going back to 3rd gen width. and what size tires would fit?
thanks in advance..
Attached Thumbnails Will these fit my camaro?-wheel1.jpg   Will these fit my camaro?-wheel-2.jpg
Old Sep 17, 2018 | 11:38 AM
Abubaca's Avatar
Re: Will these fit my camaro?
Pretty sure the fronts wont fit without big ole adapters. Stock is 0 offset. Stock rears are 16mm, but those are probably pretty close to 4th gen, so with a 4th gen rear, it should appear close to thirdgen proportions. Not sure about 4th gen widths.
As for all the little variables with ride height and brakes etc. etc., I wouldn't say for sure they would fit. ...but 0 front and 16 rear are stock, you can do your math from there.
Chris out this link. LOTS of knowledge here.
http://www.skulte.com/adapterfaq.html
Old Sep 18, 2018 | 11:38 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The bolt circle is 120mm on those wheels and not 120.65 (3rd gen). If the wheels are hubcentric than they might fit. However, if the dimensional stackup is not in your favor those won't bolt up. Especially with acorn centering lug nuts.
Poiskd
Wheels and Tires
Oct 29, 2013 11:40 AM
bummys_hotrod
Wheels and Tires
Mar 20, 2009 01:10 PM
paveuk
Dec 13, 2008 10:43 PM
ztweny8
Sep 14, 2006 10:24 PM
redlines4us
Aftermarket Product Review
Nov 5, 2004 10:04 AM
