aodhan ah02 18x8.5 18x9.5 35/30
Old Oct 2, 2018 | 02:02 PM
odin65's Avatar
I just ordered a set of aodhan ah02 wheels in 18x8.5 35mm and 18x9.5 30mm in 5x114.3. I plan on using a 1.25 adapter on the front and a 1 inch adapter on the rear, and i have a concern on the front spindle grease cap. Has anyone out there used a wheel of the same width and adapter on the front, with any issue of the grease cap not fitting under the center cap? Any help would be appreciated.
Old Oct 2, 2018 | 04:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: aodhan ah02 18x8.5 18x9.5 35/30
Ok, so I assume you know the bolt pattern is wrong and you need the spacers to alter that.
Usually a spacer will allow the caps to clear, but it's hard to tell since every wheel/centercap is different.
Worst case, kore3 and probably other people, makes a billet dust cap that look really good and can take the place of the center cap if it doesn't fit
Old Oct 2, 2018 | 09:14 PM
odin65's Avatar
Thanks for the help. As i said in my post i am planning on a 1.25 front and 1 inch rear adapter. I'm not sure the 1.25 and the wheel to cap space will be enough, thanks for the source of aftermarket caps.
Austin92
Wheels and Tires
Jul 15, 2015 08:56 PM
88iroczkid
Wheels and Tires
Feb 21, 2015 11:30 PM
UDAMON
Oct 5, 2005 07:46 AM
91NiteRida'
Jan 3, 2005 06:02 PM
tamonez
Jan 27, 2003 11:30 PM
