Backspacing vs Offset
Car: 1992 Z28
Engine: 5.7L TPI
Looking at picking up some new XXR 555s and was confused by the measurements on the site. It's showing 18x10s with a +25mm offset, but under the specs it has a 6.48bs shown. 25mm is about an inch so wouldn't that give it a bs of 6"? Or is the 10" width not including the rim flange? Just trying to figure out what size adapter I'll need to run but that was throwing me off. Thanks in advance for any help.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Backspacing vs Offset
Need to include the rim flange as you called it. Usually add 1" to the advertised width of any wheel.
Nazzz28
Mar 7, 2003 08:15 AM
twiztidz28
Apr 4, 2002 11:37 PM
88irocz28
Mar 8, 2002 11:48 AM
