Upgrading my rims and tires
Old May 3, 2019 | 10:48 PM
JonJon5.0's Avatar
What’s are some stock corvette wheels that will fit over a stock 3rd gen Hub I want to get 19 inch rims front and back it don’t matter C6 or C7 Rims I’m also doing a 2 Inch Wheel Adapter front and back so they won’t rub I’m mainly trying to fire out which corvette rims fit on the stock hub surface what size does the center bore of the rim need to be I want tire size to be 285/30-19 (Front) and the (Rear) 305/30-19
Old May 3, 2019 | 10:50 PM
JonJon5.0's Avatar
Re: Upgrading my rims and tires
I’m also planning to lower the car after the wheels and tires I’m getting a alignment when all this gets put on the tires will be Federal 595 In the Front and Nitto Nt555 R in the Back
Old May 4, 2019 | 12:32 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
you gonna have to use spacers so its not the stock hub the wheels need to clear its the spacer. if you need a set let me know i have some i'm not using
Old May 4, 2019 | 01:05 PM
JonJon5.0's Avatar
What size do you have 2 inch spacers
and where are you located
Eagle223usa
28
Mar 7, 2018 03:38 PM
brodysZ28
Wheels and Tires
Feb 16, 2017 08:21 AM
FireBirdKnight
Exterior Parts Wanted
Jul 13, 2006 02:01 PM
easySPEEDcamaro
Oct 25, 2002 08:01 PM
