Will these fit my 83Z? 17*9.5
Old May 28, 2019 | 03:47 PM
Dholland17's Avatar
Car: 1983 Z28 T-tops
Engine: 350 GM Crate
Will I need to modify bump stops, buy spacers etc?
Would 8.5 up front be safer?
If so, can I run the same tire size? I bought BFG 275/40/17
Thanks!
https://www.summitracing.com/parts/a...vanti/model/ii
Wheel Diameter: 17 in.
Wheel Width (in): 9.500 in.
Wheel Bolt Pattern (app): 5 x 120.65mm
5 x 4 3/4 in.
Backspacing (in): 5.560 in.
Offset: +8.00mm
Center Bore Diameter (in): 3.270 in.
Center Bore Diameter (mm): 83.10mm
Old May 28, 2019 | 08:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Will these fit my 83Z? 17*9.5
You will probably need a small shim/spacer about 1/4" to clear everything. The tie rod is where it's going to be close.
Or use an 18" version and it will fit right on.
Z-Monkey
Aug 11, 2003 05:35 PM
wendyz28
Jun 8, 2001 12:53 AM
Z's r Best
Dec 30, 2000 11:19 PM
