New wheels / square or stagger / offset fitment
Old May 14, 2020 | 07:05 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I finally narrowed down the wheels I want for the Camaro. Here are the specs
18x8 with 4.540 BS
18X9.5 with 5.290 BS
Bore is 72.591
Any reason a square setup with 275/35-18 would not work on my Camaro. I assume it will be about flush.
CARID says the 18x9.5 will not work on the back, I think it should be fine.
They say the 18x8 is fine on all four corners. Im on the fence. Plus I want to be sure on the tire size.
245/40-18 would be correct if I ran the 18x8's?
Thanks for some input. Oh yeah here are the wheels.
US Mag C-TEN -U129
Old May 14, 2020 | 04:23 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: New wheels / square or stagger / offset fitment
If I were you, the 9.5" wheels with the 275-35 tires would be the only way to go since they should fit with those specs.
Old May 15, 2020 | 06:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
The biggest concern is if I upgrade front brakes to a LS/LT/Corvette setup, will it push the 18x9.5 out too much?
Old Jun 14, 2020 | 11:37 PM
devianb's Avatar
For Illustration purposes this is or was ChevyKens car with TT2 17x9.5 wheels with 5.5 bs, C5 brake upgrade with a 5mm spacer and 275/40 tires. The backspacing with the spacer and big brake kit would come out to about 5 inches. The 18x9.5s that you want with a big brake kit would stick out a tad farther than that.
Old Jun 15, 2020 | 07:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
"For Illustration purposes this is or was ChevyKens car with TT2 17x9.5 wheels with 5.5 bs, C5 brake upgrade with a 5mm spacer and 275/40 tires. The backspacing with the spacer and big brake kit would come out to about 5 inches. The 18x9.5s that you want with a big brake kit would stick out a tad farther than that."
Thanks. Any more that that would just be too much.
I think I will stick with the 18x8 in front.
Here are pics of some US Mag Ramblers / 18x8 in front and 18x9.5 in back on a third gen. These wheels have the same backspacing as the wheels I want.
They are both memebers here. Hope they dont mind me using their pics.
Knight Prowl
Wheels and Tires
Feb 6, 2015 09:23 PM
camaroman350
Aftermarket Product Review
Jun 18, 2006 11:59 AM
Midland_GTA
Sep 1, 2003 06:21 AM
Superman
Aug 28, 2001 09:16 PM
