Anyone figure out a way to remove the aluminum fogging?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I have a set of original 89 IROC rims. Rims and paint are great but the aluminum surfaces are a bit "cloudy." I don't want to cut the rim faces unless I need to. Has anyone found a solution to treating the clearing up the fogging up of the aluminum surfaces?
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Anyone figure out a way to remove the aluminum fogging?
Car: '89 GTA
Engine: ZZ6TPI
The wheels should be clear coated over the machined aluminum and the coating they used back then was not very durable. The best cleaner I have found is Mothers Mag and Aluminum polish (yes, even on the clear coat) and some elbow grease, then follow up with a coat of wax. It will take out the etched in brake dust and some discoloration, but if it’s really bad, it won’t be able to be saved. Easy enough to give it a try.
if the clear is bad, then the only fix will be to chemically strip the wheel, repaint the accents and clear the whole wheel.
Engine: 350 TPI L98
Transmission: WC T5
Thx. Exactly the advice I was looking for! I'll give them a go.
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Before after good clean-up
After with clear coat striping, gradual wet sanding
Car: 90 Formula / T-tops
Transmission: MD8
you might also try some compounds if you have any around. this stuff works miracles on a lot of stuff https://www.meguiars.com/professiona...cut-high-gloss
I've used it to get stains out of paint, make cloudy headlights clear again, if your clear coat is just has a little surface oxidation, it will take it out.
