Remove only the clear coat, but not paint, on 25 slot turbofin wheels?
Wheels and TiresNeed help with wheels or tires? Got fitment issues? Have questions about tire performance and handling? Ask all of those questions here!
I want to remove the clear coat to polish out the corrosion and, for now, leave the dark grey paint as it looks to be in good condition. Right now, I don't plan on replacing the clear coat as these wheels will never again see snow/salt. Do I have any options other than paint stripper that won't make a mess of things?
Down the road I might do a proper strip, repaint, and clear coat. But not any time soon.
Re: Remove only the clear coat, but not paint, on 25 slot turbofin wheels?
Only way I can see it being done is without paint stripper. I can’t see how you can pull the clear without having it drip onto the gray. I’d recommend sanding the flat unpainted surfaces and lip. Just step the paper up to a finer and finer grit until you can polish it out.
