19X10 with 5.5" backspacing for the front, will it fit?
Old Mar 11, 2022 | 09:24 PM
Anton28's Avatar
Will a 10" wide wheel with 5.5" backspacing fit on the front of a third-gen or would you need to go 5.7" or 6"?
Old Mar 12, 2022 | 12:26 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 19X10 with 5.5" backspacing for the front, will it fit?
6" backspacing for sure. Maybe even 6.25".
And you can always add a shim but you can't remove material.
Old Mar 12, 2022 | 10:47 AM
Anton28's Avatar
Shoot I was afraid of that. I'm going to see if I can shave off 1/2 inch of the back pad and bring the wheel in with negative camber around 1/4 at the top. I found a set of wheels with the 5.5 backspacing. Trying to figure out how to make them fit.
Old Mar 12, 2022 | 01:11 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Have these wheels already been machined for the lug nut taper? Once that is done that wheel is what it is because you can't remove material from under the taper or it will weaken the wheel.
If you have the skills to do all that then you have the skills to measure out your wheel well and get this right.
Adrenaline1
Wheels and Tires
Jan 26, 2012 08:47 AM
Jason E
May 21, 2007 09:42 AM
jake_91_rs
Jul 22, 2004 11:06 AM
