Ugh, will these fit?
Old Jan 23, 2012 | 02:18 PM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
I asked 2 different places and got two different answers (go figure). Ill admit im a complete noob when it comes to anything wheel or tire related and neither place did much to help.
I have a 1982 Firebird and would like to run 18X9 wheels in front and back that have 5.3 backspacing. Now, will these fit flush (not sticking out past the fenders) and if so what spacers (if any) will i need?
On the same topic what tires would you guys recommend?
Old Jan 23, 2012 | 05:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Ugh, will these fit?
They should fit like a glove with no spacers. Should put the tire about.flush or .just in from the wheel opening
Old Jan 23, 2012 | 06:01 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You know full well that a 5.3" backspacing will NOT fit up front without a spacer, only in the back without one.
Old Jan 23, 2012 | 06:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
um, no, they will fit fine, they are 18"..... you can run over 6" in the front and clear everything....
Old Jan 23, 2012 | 06:40 PM
Car: GTA
Ummm no.....Not even with a 18". The OP can try but hope he isn't surprised when they don't.
Old Jan 23, 2012 | 06:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
are you for real??? a 18" wheel clears the tie rod, and clears the strut "lip" for lack of abetter term. they fit, i guarantee it
Old Jan 23, 2012 | 06:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
from the fitment sticky at the top of the page, if you need more proof
15-inch: 15x8 with 4 1/2-inch backspacing front and rear. Use tires with an aspect ratio of 55 or less with a section width of 255.
16-inch: 16x8 with 4 1/2-inch backspacing front, 5 1/8 backspacing rear. Use tires with an aspect ratio of 55 or less and a section width of 255.
17-inch: 17x9 with 5 1/2 inch backspacing front and rear. Use tires with an aspect ratio of 40 or less with section widths of 255 front, 275 rear.
18-inch: 18x9 1/2 with 5 1/2-inch backspacing front, 18x10 with 6-inch backspacing rear. Use tires with an aspect ratio of 35 or less with section widths of 275 fron, 275-295 rear.
Old Jan 23, 2012 | 06:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
even do a search, there are quite a few topics recently dealing with wide 18"'s. BIGMODS for instance, uses about 6" on the front with a c5 brake kit, so thats about 5.75 without, and he has plenty of clearance to the strut and tie rod....
Old Jan 24, 2012 | 01:05 PM
Car: 1982 Firebird
Engine: 2.8 N/A
O boy. lol
So.....
Would anyone else like to chime in here? Help with tire size would be great as well.
Old Jan 24, 2012 | 06:06 PM
87350IROC's Avatar
Car: 87' IROC
I agree with 86, I have measured over 6.5" of clearance from wheel mounting surface to the strut for an 18" wheel. This is with aftermarket brakes, with stock brakes you would have about 6" of clearance. 5.3" BS will fit just fine.
Here is an 18" 6.25" BS wheel on my front. About 1/2" clearance between strut and wheel.
I can just fit my finger in between the wheel and strut.
Here you can see the wheel clears the tie rod.
And here you can see the wheel clears the lip in the strut.
Old Jan 24, 2012 | 06:09 PM
87350IROC's Avatar
Car: 87' IROC
Those will fit perfectly. Excellent choice. What wheels are they?
Old Jan 26, 2012 | 08:47 AM
Car: 1982 Firebird
Engine: 2.8 N/A
Thank you for the help everyone, i greatly appreciate it.
The wheels i plan on going with are US Mags.
Does anyone have any suggestions as far as tires go?
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
