Third gen camaro rim size fitment
Old Jul 13, 2022 | 10:41 PM
Adam Bunch's Avatar
Car: 1986 IROC Z28
Engine: LS3 376 ci
Does anyone know for sure is 18x8.5 front 19x10 rear rims will fit a stock 86 iroc?
Or exactly the biggest that will fit. If not what mods you'll have to make for them to fit?
Old Jul 13, 2022 | 10:42 PM
Adam Bunch's Avatar
Car: 1986 IROC Z28
Engine: LS3 376 ci
Re: Third gen camaro rim size fitment
Old Jul 13, 2022 | 10:51 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
have you looked into the offset or backspacing of the wheels youre trying to install?
Old Jul 14, 2022 | 08:38 AM
Adam Bunch's Avatar
Car: 1986 IROC Z28
Engine: LS3 376 ci
Yea they're z06 replicas. 18"x8.5" +56 front 19"x10" +79 rear
Old Jul 14, 2022 | 08:39 AM
Adam Bunch's Avatar
Car: 1986 IROC Z28
Engine: LS3 376 ci
Old Jul 14, 2022 | 09:50 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You'll need spacers. You might rub a bit on the rears depending on how low the car is. You may need the big hammer mod too. There is no magic yes or no with wheels and tires. Many have this set-up but I am sure each has a story how they got there.
Old Jul 14, 2022 | 09:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Rears need about a 2.5” spacer. 2” may work depending on tire size. I needed closer to 2.5” over thirdgen width rear. Need to clearance wheel well up near the front of the well but also depends on tire size
front should take a 2” spacer I think
Old Jul 14, 2022 | 04:07 PM
Adam Bunch's Avatar
Car: 1986 IROC Z28
Engine: LS3 376 ci
I was thinking 285/35 on the rear
91RSHawaii
Jan 16, 2005 05:35 AM
chevyrumble83
Jun 24, 2004 02:31 AM
88formla350
Dec 12, 2002 07:32 PM
tbabeck
Jun 9, 2001 01:25 PM
