Will these work front and rear?
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
Re: Will these work front and rear?
Since no-one is answering, They might fit, if not it will be because of too much back spacing and 1 inch wheel spacers will fix that. Hopefully that's a good enough answer.
They'll be very close. As clubber said, I think you might end up needing a small spacer, due to the 5.75" backspacing. My guess is there would be a little rubbing up front. -if it were up to me, I'd stick with a 9 or 9.5" wide wheel, unless you just have your heart set on cramming in every last mm of rubber you can! I respect that if that's your goal, but just know that it comes with the expectation of a little extra effort. Whether it be research, trimming, spacers, etc. etc....it's probably not a simply bolt on. These days we all love to jump online and ask questions, which is great, but sometimes, you actually just gotta get down on the ground and start getting dirty and measuring and testing. -or....go with a known dimension, like a 9" wheel/0mm offset.
happyhapka
Wheels and Tires
Oct 20, 2018 09:19 AM
