Weld wheels / stud alignment
Old Jul 24, 2024 | 05:03 PM
JackAsserson's Avatar
92 firebird.. wondering if these weld wheels will work.
Here the studs are in a bind, won’t center
Here in this grouping I believe there’s plenty space to center the studs, but not sure if there’s too much gap
Old Jul 24, 2024 | 10:19 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Weld wheels / stud alignment
You can get shank style lug nuts and try to bolt the wheel up using the 2nd set of holes. If they thread on smoothly, then shop for hub centric rings. Double check chassis clearance / backspacing too. Bolt pattern isn't the only way a wheel "isn't a good fit."
hyperman85
Wheels and Tires
Jul 21, 2023 05:01 PM
formula00ra
May 19, 2020 10:05 AM
naterman35
Sep 20, 2007 01:29 PM
