Clear Lighted Rs Emblems All Done!!
Old Jan 13, 2004 | 10:26 AM
David Petersen's Avatar
I think this is the place to post this. I posted these before but I made some changes to make them better and got them mounted. Going on sugesstions from this fourum I changed the side ones from red to yellow to be used as turn signals. The rear one I still haven't decided if I should hook it to the brake or just us it as a side or parking marker..Suggestions???
Anyhooo I have a ton more pics but no place to host them so I can only show these two I put in readers rides. I started off wanting to blend the clear aftermarket side markers better and this really pulled it off. Total cost was about $45 most of the cost was the LED's.
Side marker
Rear bumper
https://www.thirdgen.org/rides/rideimages/ACFNAOZMB.jpg
Old Jan 13, 2004 | 01:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
wow.. thats neat.
heh, howd you do that? where did you get clear emblems from?
the only thing i would change on the rear is make the RS letters black...
that way they stand out more... its kinda hard to read when they're white. (could just be the picture though)
Old Jan 13, 2004 | 01:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
btw, in every post you make, theres a place just below where you type in called Attach file.
click the browse button and select your file... as long as the picture is smaller then 102500 bytes, it will attach it to your post.
if its larger then that, you should either resize it, or reduce the quality setting(in otherwords, compress it more).. then it will work.
Old Jan 13, 2004 | 01:48 PM
The emblems them selves are made out of 1/4" plex that I got a sheet of at Home Depot and cut out and sanded smooth. I then used chrome stickers that are actually 4th gen replicas on top. For the rear one I wanted to try for a reverse effect so i put the sticker on painted white over it and pulled the sticker off. You can't even see the little bow tie on the right side of the emblem, I may try and tirm it off in black. Let me try and attach a pic of the emblem by it's self with the led holes...
Old Jan 13, 2004 | 01:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
very cool.
what did you use to cut and bevel the edge of the clear plexi without leaving scratch marks?
or did you have marks and get them out with fine sandpaper?
Old Jan 13, 2004 | 01:53 PM
Dang I can't get these pictures to srink I have tried everything I can think of. Anyway here is another view.
Old Jan 13, 2004 | 01:58 PM
I used a hacksaw to cut out the shape, sanded with 220,400, 600 paper then hand rubbed 1500 buffing compound for a few minutes the edges turned out crystal clear.
Old Jan 13, 2004 | 02:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
it looks like you used clear silicone to attach it... that right?
hehe, the side ones just might end up being somthing i do for the heck of it one night.... very cool idea... :lala:
Old Jan 13, 2004 | 05:53 PM
FastElectrics's Avatar
Car: 89 Camaro RS
ahhhhh, Sweeeett!!!!!!!! I love it man.. I think I may try that for my car.. too cool.. :hail: :hail: :hail:
Old Jan 14, 2004 | 09:22 AM
Yes I used a tube of silcone fish tank sealer it is suposed to be very strong, plus it has a nice cut to size tube to apply with. I just sealed the edges and the mounting screw holes where the rocker attaches to make sure no dirt gets in.
One important note the silicone reflects the light very well and will light up, if you look at the Right hand lower and upper corners of the yellow marker closly you can see where the silicone pushed in and actually lights up. So either make sure you bead around the emablem are even or silocne the whole thing and work any air bubbles out so the whole marker lights up.
Old Jan 14, 2004 | 12:06 PM
MdFormula350's Avatar
nice work, looks slick!
Old Jan 21, 2004 | 09:55 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
hey that looks really cool did you try any other light color
Old Jan 22, 2004 | 09:16 AM
I originally had red in the side markers, just because I had red LED's left over from another prodject when I thought of doing this. I took the sugestions of a few poeple on this board and went with yellow just to make it a functional blinker. You could use any color LED you wanted, just depends on what look you are going for.
Old Jan 22, 2004 | 04:16 PM
Car: 1997 S10
can you e-mail me the directions of how to make the cool side markers my e-mail is snoopdoge4@earthlink.net
Old Jan 22, 2004 | 04:42 PM
Will do. I will get a few more pics tonight and email you everything tomorrow.
Old Jan 22, 2004 | 07:25 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Transmission: 700-R4
That's way toooo Koooool!!!!
It sometimes amazes me at the creativity of my fellow ThirdGen owners!
Great idea, and Very Well Done!
Thanks for sharing!
Speedy
Old Jan 26, 2004 | 09:39 PM
N/A89CamaroRS's Avatar
Car: 89 Camaro RS
Engine: LO3
Hey can you e-mail that info also? Thanks!
Old Jan 26, 2004 | 10:36 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Good job! :hail:
Old Jan 26, 2004 | 10:49 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
i would like directions as well..
twolfe98@comcast.net
Old Jan 27, 2004 | 09:51 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
So those work with your blinkers? That is a definate first!! They look great, I can't wait to see what's next
Old Jan 27, 2004 | 10:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
got any pics of how you set up the bulbs on the backside.....if not my e-mail is in my profile if you wanna hit me up on these details.
Old Jan 29, 2004 | 11:26 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
VERY unique! A job well done. I think if the RS showed light rather than light coming around the letters it'd be easier to read. Either way, very cool!
Old Jan 30, 2004 | 08:53 AM
I had the rs showing light on the rear emblem but the picture I posted is to far away and doesn't show it very clearly. If I had used a darker color other than white it would have showed up a lot better.
I am putting together some directions (and what not to do's) and pictures. The pics I took last night didn't turn out so I will try for Monday to have it all together.
Old Feb 4, 2004 | 12:48 PM
Hey all I finished the directions and some pictures. I was just waiting for the sicker supplier where I got mine form to confirm that are willing to make IROC and firebird stickers also as mine is an RS. I did it all on a word document, zipped it and emailed it to all that asked. Due to the pictures the file is rather large. Maybe we could add this to the tech section? I have no skills for adding this kind of thing in web format.
Old Feb 4, 2004 | 01:02 PM
Car: 89 Camaro RS
Engine: LO3
Hey David, could you e-mail the info? If you already tried I didn't get it my polk_cavalier@msn.com. Thanks alot!
MERLIN
Old Feb 4, 2004 | 01:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
could you email it to me too?
MrDude_1@excite.com theres a _ between Dude and 1... like my username... you just cant see it when its underlined.
Old Feb 4, 2004 | 01:14 PM
Sent and sent.
Old Feb 4, 2004 | 04:26 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
make some for an iroc... i might buy
Old Feb 4, 2004 | 06:12 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
can you mail me directions as well...
Old Feb 4, 2004 | 06:45 PM
X86TRANSAMWS6X's Avatar
Car: 87 Conquest TSI, 86 Fiero GT
i got to get in on this.......................me too
kx250cc43@wmconnect.com
nice job btw
Old Feb 4, 2004 | 07:51 PM
Car: IROC-Z
i would like instructions too dbdiamondbackbmx@yahoo.com
Old Feb 4, 2004 | 11:03 PM
xpndbl3's Avatar
Car: 1984 Z28
Old Feb 5, 2004 | 08:26 AM
Car: 1997 S10
hey could you e-mail me the directions my e-mail is snoopdoge4@earthlink.net
Old Feb 5, 2004 | 09:07 AM
I emailed the document to everyone some people twice. Did anyone get the directons???
My work security must have blocked them. I will email it from home tonight.
Old Feb 5, 2004 | 09:41 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i did not get mine
i was hoping the email was just slow, but i just checked it.. its been 24 hours...
Old Feb 5, 2004 | 09:47 AM
I am checking with the website admin. to see if I can get this posted as a tech article.
Old Feb 5, 2004 | 10:19 AM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
i didnt get any mail...
or
twolfe98@yahoo.com
Old Feb 5, 2004 | 01:03 PM
Car: 89 Camaro RS
Engine: LO3
Yeah I didn't get them twice either. Thanks for trying david, let us know what's going on so we can be like you!
MERLIN
Old Feb 5, 2004 | 03:41 PM
Ok everyone cross your fingers. I broke the file down and sent everyone two emails one is the text directions and the second is the number coordintated pictures.
Old Feb 5, 2004 | 03:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i got one of them.. the one with just the text... pics didnt come thru though
Old Feb 5, 2004 | 08:23 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
Very good exp. thank you much... good picts as well
Old Feb 6, 2004 | 08:33 AM
Car: 1997 S10
thanks david got mine
Old Feb 8, 2004 | 02:33 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
May as well jump in on the bandwagon.
pmd6267@rit.edu if you get a moment.
It looks awesome!
Old Feb 8, 2004 | 04:37 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I have a suggestion. If you frost the rear of the acrylic by sand blasting it you wouldn't see the car color as much through the lens.
Lon
Old Feb 8, 2004 | 04:44 PM
jon_volk's Avatar
why dont you submit the instructions and pics to a forum moderater to be posted in the tech articles section instead of emailing 100 diff. people
Old Feb 8, 2004 | 05:53 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Old Feb 9, 2004 | 09:08 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I would love some directions. PLEASE. tibo1992@yahoo.com
Old Feb 9, 2004 | 04:40 PM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
me too if it hasnt already been posted in the tech articles. very cool I really like that idea! Whever ya get the time!
thanks
Old Feb 17, 2004 | 09:15 AM
Hey all this has been posted in the tech articles!!!! Thanx Dirk!!!
https://www.thirdgen.org/newdesign/t...remblems.shtml
Old Feb 17, 2004 | 10:58 AM
Engine: 5.0L TPI
Axle/Gears: 3.08
Awesome Thanks!
