Why not enough low end torque?!!
Old Feb 24, 2005 | 07:31 AM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
I tried searching about this but couldn't really find anything.
My car hasn't got enough low end torque, infact it feels really weak in the lows. I keep reading how much low torque the tpi has... but why not mine?!
I'm not the only one that noticed this. Had it to a mechanic testing a possible bad transmission mount and remember he commented on how it seemed to lack power. We didn't discuass this further because then this wasn't the issue.
But I'm sure there must be something wrong. It's fine, even excellent in high rpm:s, why not in lows?? I've recently replaced fuelfilter, airfilter, sparkplugs, cables, cap and rotor. Things that might need changing are wacuumhoses and injectors.
Any idéas on what is wrong with my lovebird???
Old Feb 24, 2005 | 10:44 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
MAF or TPS
Old Feb 24, 2005 | 03:36 PM
sellmanb's Avatar
Car: '86 Berlinetta
any mods done to the car?
Old Feb 24, 2005 | 04:36 PM
/\/3\/\/l8l3's Avatar
If your running open exhaust (no cat/ high flow muffler) it really feels like it changes the rpm range...seems like most people don't understand this and go for noise and end up killing their in town gas mileage
Old Feb 24, 2005 | 04:46 PM
sellmanb's Avatar
Car: '86 Berlinetta
he never stated that he's running open exhaust though. Was that from another thread that I missed? If so, I apologize.
Old Feb 24, 2005 | 05:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exhaust flow changes don't affect MAF like they do SD.
Old Feb 24, 2005 | 06:00 PM
Car: Red '89 GTA
Engine: TPI LB9
Yes actually the cat has been replaced by a straight pipe and also it's supposed to have somekind of chiptuning made by some company called macnamara tuning from when it was new. The cat was "deleted" much later... I fear this could be the cause of the torque-loss because the chip wasn't tuned for this. But I'm no chip expert so wha'do I know. Also the muffler has been gutted a bit, otherwise everything is stock.
Let me get this straight... running "open exhaust" is bad. I thought it just eases the flow of it and gives the car more hp:s... does it lessen torque?
Old Feb 24, 2005 | 06:38 PM
five7kid's Avatar
With speed density EFI systems, such as TBI and '91-'92 TPI, the "conditions" are measured and the fuel tables "estimate" the flow that those conditions would produce. When you do something to alter the flow capacity of the system, such as exhaust or increase the engine displacement, the assumptions under which the fuel tables were established are no longer valid. However, with a mass air flow system such as you have, that really isn't a problem.
I'd suspect, however, that your "custom" chip isn't doing you any good. If you still have the factory chip, try it and see what happens.
Old Feb 25, 2005 | 03:46 AM
Car: Red '89 GTA
Engine: TPI LB9
unfortunately the factory chip is long gone... don't think it was ever even brought here to finland when it was shipped over in '89.
But wouldn't the stock chip also be "out of sync" with what I'm running right now? And why would the "custom" be even worse?
Is the stock expencive if i choose to try it?? Keep in mind I probably woun't find any used parts here in Finland.
I know the chip is located somewhere behind the "glove-bag". Tried taking some parts off once with my brother to get to it and check what kind of chip it actually is (programmable for instance?), but since we really didn't know what we were looking for we gave up. Is there like a ton of crap in the way before u get to it? Would really like to see some pics of the picking apart and the chip location to get an idéa. Have tried searching for this here but never really found any pics... only of the chip itself.
Old Feb 25, 2005 | 07:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The chip is in the ECM which is under the dash. Opposite side of the steering wheel, silver box with two connectors and lots of wires. Would have 'service number 1227165' on it.
Small cover with 2 screws, chip is under that mounted to a MEMCAL. Now, with the aftermarket chip there may be an adaptor in place. If so the chip will be right under the small cover. With the MEMCAL mounted on it's side.
RBob.
AussiePr0nCar
Mar 6, 2020 04:04 PM
jklein337
Sep 19, 2018 06:23 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
