Repacement ECM for 1227165?
Car: 1983 Trans Am 1986 Trans Am WS6 1985 Fiero SE
Engine: 83' LG4 305 86' 5.0 TPI 85' 2.5 Fiero
I recently bought an 86 TA 5.0 TPI. The car has sat for a few years but is in excellant shape. The computer in the car now is a 16698259, which I thought to be wrong. Is this a replacement for the 1227165 ECM? I am going to check the prom number as it may not be right. A scan check says incompatible prom. Thank You for any help on this one. l
Thanks Dave, and yes you are right. It is a 16198259 not the 166 I first typed in. I am pulling the prom tonight and will be looking for the right one tomorrow. (the scanner says incompatable prom) It is looking for a VAT system that does not exist on this car. I am fortunate to have a good freind who is a smog tech instructer and the car is at the school where all the test equipment is.
Piston Dude
Piston Dude
Car: 87 IROC Z-28
Transmission: AT
Would the PROM from the '165 ECM work in the 16198259? I was thinking of replacing the ECM, just wondered if the PROM is interchangeable for both?
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Yes, the MEMCAL is the same -- it's the same ECM, just an updated part number and supposedly some reliability improvements, like better quality soldering.
efiguy
Sep 27, 2015 01:30 PM
