Tires
Old Mar 25, 2002 | 09:32 AM
gruveb's Avatar
Car: 1989 IROC-1
Tires
Howdy....
Well time to buy new tires for my 84 Z28. I have some centerline rims on right now but am thinking about going back to the stock rim....either way the rims will be 15"
What size of tire can I use and what looks nice. I of course want a slightly more aggressive look than just stock.
I have heard 255/60/15's....anybody got pics?
Old Mar 25, 2002 | 10:08 AM
CODY BEHNKE's Avatar
Don't go bigger than 235/60/15, well I guess thats just my opinion. A bigger tire is only better on a bigger rim.
Old Mar 25, 2002 | 06:19 PM
82camaro's Avatar
Car: 82 camaro SC
235/60 all the way around will probably be best. 255's are usually a bit much on the front. I used to run 245/60R15 back when I had 15's. They rubbed when turned all the way left or right. It's not a very good picture:
Old Mar 25, 2002 | 06:36 PM
darbleinad's Avatar
Car: 84 Trans Am
i have 235/60R15s on the front and 255/60R15s on the back. i had 235/60R15s on the back before, but i wanted a wider and taller tire on the back. i am sorry i dont have any pictures right now. my cousin runs a tire shop and the 255 width is the largest that can fit on 7" wide rim (at least in the 60 series). i use Kelly Chargers. i like the raised white lettering that is on them.
Old Mar 25, 2002 | 07:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
My borther has 265/50/15 Goodyear Gatorbacks on 7" rim on the rear of his Firebird. They are wide and really mean.
Old Mar 25, 2002 | 07:15 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I'm running 265/50/15s on the back and 215/60/15s on front. They're BF Goodrich Radial TAs. These are the best pics I could find. You can only tell so much from these shots but in real life they look pretty wide.
Old Mar 25, 2002 | 07:45 PM
darbleinad's Avatar
Car: 84 Trans Am
do you have anymore pics of that exhaust setup, No4NJunk? looks liek ground clearance may be tight, how you found it too be?
Old Mar 25, 2002 | 07:53 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i run 245/50 15 on a centerline convo pro............course i only have 2 tires to chose from the euro ta from bfg and the dunlop sport 8000..............i have the euros now.........as far as tread wear goes they last a real real long time but they arent very good in the turns..........gonna try the dunlops next which i heard is a better tire
Old Mar 26, 2002 | 12:05 AM
No4NJunk's Avatar
darbleinad,
Sorry but I won't have anymore pics until this weekend. Believe it or not ground clearance is not a problem. I have not scraped once since have it put on. I have air shocks in the back to help with that. If only I had a way to let you here it.
Old Mar 26, 2002 | 08:43 AM
gruveb's Avatar
Car: 1989 IROC-1
My tires were so dried and worn out on the side walls I figured I'd better pick up some wheels soon. I got a set of 15 x 9's American Racing Stics 5. I rounded them out with 235/50r/15's.
Here's the link. I'll post some pics later.
http://www.americanracing.com/wheels...ticks625Chrome
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
