9-bolt posi?
Old Jun 25, 2002 | 12:00 PM
mike89z's Avatar
Car: 89 Iroc-Z
9-bolt posi?
My posi works sometimes (too slabs if Im goin straight) but not when im turning slightly to one side. It seems like maybe the posi is getting a little worn so I was wondering if it would help if I threw in another bottle of GM friction additive. I thought I read that this helps. Anybody?
Old Jun 25, 2002 | 12:28 PM
KeithO's Avatar
The 9-bolt is a cone-type posi. The friction modifier is designed for clutch-type posi's. Note that according to a GM TSB, the 9-bolts are not supposed to get the posi additive.
Beware - this is a controversial issue (for some inexplicable reason) on this website.
Do a search - a while back I documented all of GM's statements regarding the 9-bolts and posi additives.
If it's any help - my rear end gear oil was replaced 10,000 miles ago and the posi additive was put in. The posi stopped completely working. I drained it and put in Red Line Gear Oil for non-posi rears and my posi works better now. Coincidence? Hard to say. Just one man's experience.
Old Jun 25, 2002 | 03:00 PM
mike89z's Avatar
Car: 89 Iroc-Z
Really, thats news to me. No additive..... interesting. Ill do a search and check it out. Thanks
Old Jun 28, 2002 | 01:14 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Let me know what you find. I have "mystery 9 bolt" seems to be a 3.08 posi, but only posi like yours. maybe thats how they are made?
Old Jun 28, 2002 | 04:34 AM
KeithO's Avatar
No that behavior is not normal. The cones are starting to wear out. An alternative to replacing the posi unit itself is to shim the posi cones. Another guy at this site (Larry Burd) has done this.
Old Jun 30, 2002 | 07:01 AM
ausrs's Avatar
some 9 bolts "chatter " going slow with a small amout of lock applied to front wheels IF your car does that ad the aditive and it will stop !
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
