300hp?
Car: rally sport camaro
300hp?
i have a lo3 and i was woundering how hard is it to have a lo3 engine with 300 horse power on budget
what gains will these mods make :
lt1 cam
vortec heads
headers
exhaust
intake
lt1 cam
vortec heads
headers
exhaust
intake
Car: 91 RS
Engine: 350 TBI
You'll need a bigger cam than that to make 300. From what I've seen/heard. . that stuff you mentioned can make an honest 240-260 at the motor with some good tuning. . . should make gobs of torque though.
thanks for the info. i was just woundering before i decide weather im gonna get a 350 and build it slowly or just do up the 305
Car: 1991 Camaro RS
Transmission: WCT5
JPrevost and I put my motor DesktopDyno with ported l98 heads put out around 300 at the flywheel on a 305 .030 over, i think a little less.... dont remember exactly but i do remember him telling me that #
EDIT:
300hp@5000rpm
310hp@5500rpm
EDIT:
300hp@5000rpm
310hp@5500rpm
Car: 1983 G20 Chevy
My power output and engine mods are in my signature. A very cheap and simple build for the results as long as you don't mind spending some time on the heads. It is a .040 over 305 that has tugged a 5,300 lbs G-Van to a 9.89 @ 69.08 in the 1/8 mile with a 2.19 second 60' time.
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
The
button is your friend my friend. You could almost put in your exact thread title and get a couple hundred thousand hits
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
EDIT:
300hp@5000rpm
310hp@5500rpm
EDIT:
300hp@5000rpm
310hp@5500rpm
Build something bigger to hit your goal or spray it...
Car: 91 Camaro RS Convertible
Transmission: 5-Speed
I agree, you want 300 rear wheel horses, you don't build a 305. If you're on a budget, then you can throw some good parts on your 305 to pick it up, but wait and see what you get out of it. Don't go into it expecting 300 HP only to be disappointed. Got a little captain in ya brody?
My new handle...
Car: 91 RS
Engine: 350 TBI
I like where this thread is going.
. . . that reminds me, I think my "air/fuel ratio" might be running a little lean. I think I'll go remedy that.
Car: 1983 G20 Chevy
Originally posted by brodyscamaro
That program is awesome for giving you numbers higher then what you will get in reality...
Then again perhaps since the converter stalls around 2,400 RPM it is playing with the numbers at peak torque as this is estimating peak torque about 500 RPM higher than recorded.
RPM-------HP------TQ
2,000-----110-----288
2,500-----143-----299
3,000-----176-----308
3,500-----218-----327
4,000-----258-----338
4,500-----293-----342
5,000-----316-----332
5,500-----325-----311
6,000-----317-----278
6,500-----295-----239
Here is the 300 RWHP version= 300 RWHP and 325 ft/lbs, simply open cut-outs.
2,000-----117-----306
2,500-----151-----318
3,000-----186-----326
3,500-----228-----342
4,000-----269-----352
4,500-----305-----356
5,000-----331-----348
5,500-----345-----330
6,000-----344-----301
6,500-----330-----267
Finally my 245 HP torque monster with 245 RWHP and 340 ft/lbs.
2,000-----139----365
2,500-----171----359
3,000-----204----356
3,500-----233----349
4,000-----254----334
4,500-----268----313
5,000-----267----280
5,500-----250----239
6,000-----220----193
Originally posted by jimp2001
personally, I'm a fan of private stock
And on DD2000, I still don't think its numbers are very accurate....
Just to chime in on DD2000:
I've tested DD2000 against a lot of cars that I had accurate numbers - I've also done a lot of high level mathematical modeling myself (though not specifically on gasoline engines) - and l have to say this ...if you tell DD2000 the truth it will usually tell you the truth also (at least to a reasonable degree of accuracy). That being said, it is hard to get perfectly accurate numbers for head flow, CFM, etc., so people often over-estimate what they actually have. Even a very slight change in head flow can cause massive changes in output torque and hp. ...Soooo, if you're going to take DD2000 seriously you have to be as honest and realistic as you can when you enter the info. Don't forget that it is very hard to account for changes due to forged cranks, moly rings, windage trays, etc, but these things can affect motor output. That being said, DD2000 even underestimates cases like this. Usually it isn't off by more than 5% either way ...if you tell it the truth.
Casey
Casey
Car: 1991 Camaro RS
Transmission: WCT5
Originally posted by markuzzz13
what are u currently running in the quarter with that set up and how much did the engine cost you overal
Car: 91 Red Sled
Hold the phone... who said I was using DD2000?????
It's DD2003
. DD doesn't report an accurate hp number. What it does do is report an accurate point of peak volumetric efficiency which in turn gives you a good idea of what your torque curve will look like.
As an example; vortec head simulations in DD don't come out very well. The reason for this is the chamber design. The port flow might not be classical and to universally group heads on an ONLY airflow basis doesn't work. This is where DD falls short, but again, who said this was the end/all tuning tool? It's just a TOOL, a decent one when you know how to use it.
DD2003 is better than DD2000 in that it takes more things into acount to give you a better picture.
The only reason I use DD2003 is because the better more accurate software is out of reach. I can't afford $8000 for a single license for Virtual 4-stroke
. Oh well, I'd much rather spend that $8000 at a drag strip anyways
It's DD2003
. DD doesn't report an accurate hp number. What it does do is report an accurate point of peak volumetric efficiency which in turn gives you a good idea of what your torque curve will look like.As an example; vortec head simulations in DD don't come out very well. The reason for this is the chamber design. The port flow might not be classical and to universally group heads on an ONLY airflow basis doesn't work. This is where DD falls short, but again, who said this was the end/all tuning tool? It's just a TOOL, a decent one when you know how to use it.
. Thread
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
