Possible solution for the 4th gen 'bird door panel gap
Old Aug 24, 2004 | 12:49 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'm in the middle of the 4th gen interior swap and have come to the door panels. As some may know (if you are using the firebird door panels), there is about a 1" gap betweent he panel and the window. The Camaro panels may or may not be the same way, not sure. But I'm not ver fond of that gap, so here's my solution: Use the 3rd gen trim pieces, like thus:
Take the trim panel off and remove the factory window sweep (you will be using the 4th gen sweep). The panel is the bottom, the window sweep is above (the one pictures is the 4th gen sweep)
Using the existing "Tabs" on the trim, I will bolt the sweep to the trim, as pictured above.
That's how it rests. The 4th gen sweep is pressed firmly against the window. Looks bone stock. (notice i took off the triangle bracket for the 3rd gen door handle). I got mad at it.
I dremel'd the little tabs that attach to the sweeps off on the backside of the 4th gen door panel. Wear goggles, things fly at your face.
Dummied up, that's how it looks. Pretty good if you ask me. No more little gap. (I'm still going to sand it down so the transition is more smooth. Tomorrow (later today?), I will bolt things down and clean it up. I'll post a fwe final pictures that shows how it looks.
Old Aug 24, 2004 | 06:55 AM
scauffiel's Avatar
Damn dude... I've been staring at those pix for ten minutes now and have no idea what you did. How about a closeup of the top of the door panel up top (the area up top near where it meets the window). I can't understand what you did - probably just need some more caffeine...
Steve
Old Aug 24, 2004 | 08:04 AM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
ok.. my question is did you have to cut the 4th gen panel so that it will shut? that is what i am running into.. where at ? and how do you plan to cover the gap that is cut? i am at the same stage...
Old Aug 24, 2004 | 11:14 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The 3rd gen sill is mounted like it would be from the factory. The door panel (4th gen) rests right over it. Like stated, the tiny tabs on the back of the door panel need to be ground off so it sits flush, or flush as can be, with the factory trim piece.
As for shutting, I am cutting at the weather stripping on the door and plan on grinding down and fiberglassing or somehing, the A-trim piece so it contours the door panel. Right now, it gets about 2" from being fully closed an hits. I may trim the back enda bit, too. Depending on how bad it is. But it doesnt look too bad.
Old Aug 25, 2004 | 03:21 PM
Faded's Avatar
Car: '91 Firebird
I remember reading something about the lower section of the door panel needing to be cut? Yours looks perfect just about.
Old Aug 25, 2004 | 05:12 PM
IHI's Avatar
IHI
I never had a problem when I installed mine with the gap on the inside against the window, even though I heard other had. I have a problem when the door is shut looking through the glass to the inside of the car-I'll use the drivers side for this explanation so you can visualize where I'm at.
The area above the door exterior door handle-that corner of the insdie door panel, i was not able no way no how to get it to seat fully onto the door so I can see the rivet holding the interior window sweep. Or I could say the top rear part of the door panel does not go down all the way. Everythig else seemed alright, just that one top corner is all.
Plus I had to shave a bit out of that area too so the door would shut, I had just painted the car and installed new weather stripping so assumed it was just stiff, but still had to grind a little out of the top rear corner for it to shut right. Same with the front top corners of the panels, had to grind a little out there too.
Old Aug 25, 2004 | 10:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Haven't done the driver side yet, I'll see how that goes....I'm having a hard time visualizing the area you describe, which really doesn't help much.
Yup and yup. It hits the bottom side of the A-trim. Not sure how im going to take care of that yet. And i took a knife to the weather strip and cut it to the shape of the door panel. I really dont want to mess up the door panel itself, as people see that more than they do the weather stripping.
Thanks! There is a small portion of actual door that sits lower than the panel, however, due to what i have done with the doors, mine (the panels) sit just a tad lower and the gap really doesnt show up, even with the door open. Ill try to take a picture with the door shut so you can see how it fits closed.
I have found that this is one of those things that has to be fudged a tad in order for the best looking fit. But thus far, I'm pleased with how it looks. Very streamlined, to me at least.
Old Aug 26, 2004 | 09:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
That's a better shot of how it will sit.
Door shuts completely (with A-trim piece off), stupid flash, the door panel is black, too.
That's how much clearance I am left with on the bottom. It matches up nearly perfectly on the vertical edge, except for the little corner that kind of wings back.
Old Aug 27, 2004 | 12:41 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
That is sweet.
Does the handle have to be moved? I thought I remembered someone saying you had to move the inside door handle one way and make that work? Please clarify because I would really like to put some 4th gen door panels in my car.
Old Aug 27, 2004 | 01:01 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Haven't touched mine. The lock cable needed work.
As you can see though, the handle itself needed trimming.
Old Aug 27, 2004 | 10:44 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Congrats, looks really good...
Old Sep 5, 2004 | 12:33 PM
Faded's Avatar
Car: '91 Firebird
Hey guys, I picked up some door panels from the junkyard today. They're from a 94 Camaro though. I'm not sure why there's a problem with a gap at the top for you guys though... I set it up and it sat very flush up against the window with no gaps after cutting down a small fold of plastic under the window sweep.
Some other things I notice though...
The the top rear corner does indeed need to be ground down. But from what I can tell, this doesn't have to be a hack job to make it look good. Mine have carpet in that area, and it seems like you can cut it down to the right angle and then just pull the carpet back over it and it will look great.
These doors have a different mounting system. Thirdgens have the cardboard backing with the plastic clips that pop into the door itself. These fourthgen panels have L shaped plastic hooks on them that you just slide onto the door. I just cut off the hooks to solve this problem. I think I'm going to make a template out of 1/4" MDF that sticks to the back of the door panel that will make it hold onto the door just like the old panels did.
And finally, the only *major* problem I see with these doors is the map pocket at the bottom. It seems to recess into the door about 3/4". This makes it stick this far on the bottom. I'm not sure what I need to do about this. Modifying the door panel to remove the pocket would probably be the easiest, but I'm not sure how good this will look. My other option is to modify the door itself to accept this recess. Unfortunately though, one of the bolts for adjusting the window is very close to the area I'd need to modify.
Anyways, I'll let you guys know how it turns out.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
