Vortec Heads #906 VS #062 casting
Old Sep 5, 2003 | 11:08 PM
iroczman380's Avatar
Well which is better!!!
the vortecs are great heads, but you can get the 906 or 062 castings. Supposedly the 062 are better, , because of the exhuast side i guess.
Is this really true??
Has anyone used the 906 appossed to the 062???
Someone enlighten me on the differences here and if i should pay the extra 100 for the 062.
Old Sep 6, 2003 | 05:25 PM
justinhebert's Avatar
Im not 100% sure but I think the only difference is "some" of the 906 castings came with hardend seats installed and that made a slight loss of flow at low lift. Personally I dont think 062's are worth $100 more.
Old Sep 7, 2003 | 10:51 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Chevy Hiperformance Magazine was one of the first publications to "break" that rumour. justinhebert is correct in the reason but since the news, the magazine has been enlightened and has retracted it's statement. There is no difference in flow between the two is the current thinking. I have a set of 062's and a set of Topline 906 replacement castings. If you can afford a couple of hundred more bucks, the Topline's are superior to both factory 062 and 906's. They have a thick deck that has plenty of material to mill to a 50 cc combustion chamber. They flow better. They have the modifications already completed on the valve guides and spring pockets for big cams. I got my new bare set of Topline 906's for $410 including shipping from Yoder racing. I could have assembled for another $200 but have opted for a little bowl and port work.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
