anyone done the 455 swap on a third gen
Old Apr 9, 2001 | 11:00 AM
72BuickGSX's Avatar
hi guys, i know there is a few people on this board running pontiac blocks in there third gens, i was wondering if anyone might have a pic of there engine, so i can kinda see how things might fit, and how far the motor sits back, im currently having a 455 rebuilt to put in my 86z and i plan on making my own headers, so would like to see how cramp it is with the motor in there, allso if the crank clears, any help ? the swap is alot of effort but the rewards of 500 ft pounds of TQ im sure will be worth it
Old Apr 9, 2001 | 07:52 PM
ede's Avatar
ede
i'm sure someone has, but i don't know who. first thing i thought of is the trans you have isn't BOP so you need a new trans. then comes the torque arm, how you going to do that? spohn's bolts to the floor pan and not the trans, but cost 400 dollars. might try b&m pn 30299 and see if it'll work with a BOP trans. good luck
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 9, 2001 | 09:54 PM
72BuickGSX's Avatar
the tranny im going to use is a pontiac 350 that came out of a 71 lemans allready ordered a trango kit for it and the b and m changover kit,
Old Apr 9, 2001 | 11:46 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
I have a Hot Rod magazine from a few months ago, and a guy shoved a buick 455 into a 87 trans am i think. He used a adapter and kept the 700R4. The motor was somewhat mild and it ran in the 11's. It sounded like the swap wasn't that bad. When I find it, I'll try to post it.
89'Camaro Convertible,96'firebird wheels,79'Z28 hood scoop, Dark yellow green paint from Bonnevilles, tan Mr. Mikes leather interior,Macewen white face gauges.
Dreaming of a RamJet 350,
Open element
Jet fan switch
180 degree thermostat
2nd place is always the first loser!
[This message has been edited by 89rsvert (edited April 09, 2001).]
Old Apr 10, 2001 | 03:13 AM
82suped-up-coupe's Avatar
hey 72buick
I customer at a shop I work at just had the 455 swap done in a 91 Z28
email me at rspire1@yahoo.com and I can send you some pics
(I promised not to show anyone, so you'll have to keep them to yourself)
btw it is a very nice swap
Old Apr 10, 2001 | 10:03 AM
72BuickGSX's Avatar
if you can find the article would be a great help, i try to look for it allso thanks, for the help
Old Apr 10, 2001 | 11:37 AM
88 Formula's Avatar
The February 2000 Hot Rod has a 92 Firebird with a Pontiac 455 that runs 9.25 at 143.02 (no bull) with a 10 inch tire and no nitrous. It has a TH 400 trans and 12 bolt rear. The guy runs the National Muscle Car Association circut. His name is Neal Owens from Wilmington, Deleware. The article has a good engine compartment photo; looks like it fits pretty good. Indian Adventures is coming out with headers and mounts for this swap.
Old Apr 11, 2001 | 11:27 PM
89rsvert's Avatar
Hot Rod Magazine June 2000 pg70. It is a 1987 Trans Am with a buick 455. He used a trans-dapt adapter to make the 700R4 bolt up. Still uses stock rearend with 3.23's. It has some expensive parts in the motor, but still uses original iron heads with some work done to them. The install looks very neat. It says at the top of the first page that it runs 11's. Sounds like a kick **s setup.
Open element
Jet fan switch
Old Apr 18, 2001 | 08:59 PM
Justa6's Avatar
Finally, someone thinkin along the same lines as me and my brother!! My brother just purchased a '83 base Camaro and my best friends uncle has an Olds 455 for sale for REAL cheap (yes, its a complete motor) If you find that magizine article, be sure to post it! We could use all the help on this swap we can get!
Old Apr 19, 2001 | 09:03 PM
88 Formula's Avatar
How about a Caddy 500? They are a popular swap in the G bodies.
Old Sep 10, 2002 | 09:25 AM
LT1guy's Avatar
Car: 1987 Trans Am
Anyone else have any 400/455 swap pics, or ideas? I'm considering this swap in a 87 TA.
Old Sep 10, 2002 | 03:47 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the 2004r came in B.O.P patterns as well.Just gotta have it built right and I could be mistaken,but the tail shaft of a 700 should bolt up to the tranny.......................................
Old Sep 11, 2002 | 07:26 AM
LT1guy's Avatar
Car: 1987 Trans Am
Redraif and I are putting one of those in an International Scout 4WD...got it out of a 72 Eldorado for $100! I heard there is a guy in California with one of these motors in a 3rd gen bird.
Old Oct 11, 2002 | 03:10 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
LT1guy and others.........
I bought a used copy of the June 2000 Hot Rod that had the Buick 455 TA article for $7.50 shipped. I'll scan them in and post a link this weekend.
Old Oct 17, 2002 | 11:40 PM
dock's Avatar
the 2004r is the way to go tranny wise,a well built one will handle the power your talking about,you just have to move the crossmember back about and use the driveshaft for a turbo 350.i had a stock one from a gn behind a 350hp pontiac 400 and it lasted a year with me beating on it all the time. other than notching the frame to clear the oil filter the 455s fit pretty good. good luck,Doc
Old Oct 18, 2002 | 11:14 AM
Momar's Avatar
If you could get those scanned I would be verry interested in seeing it.
Ben
cam-mike
Aug 24, 2015 07:23 AM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
