Holley TBI w/Edelbrock Performer Intake?
Old May 30, 2002 | 12:32 AM
Nate Hanson's Avatar
Hey Guys...
My buddy is selling his Holley 670 TBI and I wanna pick it up if it will work on my Performer TBI manifold? I could use the extra airflow.
BTW..the engine is a LO5 in my 91 S10.
Nate
Old May 30, 2002 | 12:52 AM
Tas's Avatar
Tas
seems like a waste since the edelbrock TBI intake has stock 1-11/16" bores and teh 670 Holley has 2" bores. You could try to have the edelbrock intake bored out but a messup could cost you the manifold.
Old May 30, 2002 | 07:04 AM
JeffC1500TBI's Avatar
I dunno about boring it.. that's the 3704? edelbrock told me not to attempt that as it would hit the water jackets..
Old May 30, 2002 | 10:18 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Edelbrock told me the same thing,it's ok to chamfer the bores, but not bore them out.If you're gonna run the big throttle body,
I'd change the intake to a four-barrel carb intake with an adapter.
(I'm running the Performer TBI and Turbo City Ported Throttle Body)
-Rich-
Old Jun 10, 2002 | 06:03 PM
JuGrNuT350's Avatar
I have the Holley 670cfm TB w/ Perf. intake, but I bought it that way w/ the bores enlarged & everything.
-Timbo-
Old Jun 11, 2002 | 12:17 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
You could always screw Edelcrap and go with the Holley Pro-Jection manifold. I believe it has 2" bores.
Old Jun 11, 2002 | 02:29 PM
Car: 92 Camaro RS
The Holley manifold has the big bores but I don't think it has EGR, so if you need to pass smog that could complicate things.
-Rich-
Old Jun 11, 2002 | 03:37 PM
DM91RS's Avatar
Car: 91 RS
-Rich-
It has egr
Old Jun 11, 2002 | 04:04 PM
jagone's Avatar
I've read other places on the board that due to either the location or the angle of the EGR on the projection manifold, you need to run a Truck EGR valve, or a TBI spacer. Neither is a big deal at all, I just thought you would want all the info when deciding on your intake.
I plan on doing a 350 swap and will probably use the performer with an adaptor plate. Or I may just go with the cheaper of the 2 setups. I've not heard/read of either being better or worse than the other. I have seen complaints with the Edel TBI intake, so I'm definately not going that route.
Old Jun 12, 2002 | 02:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have the edelbrock intake and I like it. It may not be the best but it was a dirrect bolt on. Everything bolted back up were it was supposed to and the only thing I had to go was bend my fuel lines a bit. If Holleys EGR wasn't different i would have most likely gone with that. However I have heard that the Holley intake doesn't fit as well.
Old Jun 26, 2002 | 01:57 PM
Audiman's Avatar
Nate Hanson
I am told by a guy with a holley TBI that it works great. The stock bore is smaller, but holley makes an adapter plate #17-46 to adapt the 2" bore to the 1 11/16" bore. Stock only flows 480cfm so the adding of the holley would be a definite improvement even for a stock engine.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
