MacEwen White Faced Gauges
Old Apr 24, 2002 | 12:46 PM
Scott Fleming's Avatar
Car: '89 Trans AM
I just orderes a set of these for the old T/A. Have any of you bought the set with the volts/fuel temp/oil gauges uncut? This requires removing one of the needles from each of the two gauges on the right. Any help is appreciated. TIA
Old Apr 25, 2002 | 03:21 PM
Kandied91z's Avatar
if they are overlays the whole point is not having to remove any needles.
if your having problems you should call ryan, with his overlays your not suppose to remove the overlays or have to cut.
Old Apr 25, 2002 | 08:25 PM
PopaPork's Avatar
WOAH WOAH WOAH, you dont have to remove the needles with those McEwen gauges? Any got picks before they put them on?
Old Apr 25, 2002 | 09:06 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Here is a picture of one of my white face guage overlays that I have laying around. The z28 on it I added!! They are really easy to install.
Old Apr 25, 2002 | 09:08 PM
85maroz28's Avatar
Here is a shot of the back with the double sided tape!!
Old Apr 25, 2002 | 09:09 PM
85maroz28's Avatar
Here ia a shot of my first set in my car.
85maroz28's Avatar
And the picture
Old Apr 25, 2002 | 10:27 PM
jawzforlife1's Avatar
so there is tape onthe back, what if you want to take them off some day. Are you going to have sticky marks were the tape was, or do you just use GOO GONE. I dont want to permently Fu(ck up my black gauges.
Old Apr 25, 2002 | 10:54 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Transmission: T-5 w/centerforce dual friction plate clutch
where did you order those gauges? i like to get some
Old Apr 26, 2002 | 01:37 AM
PopaPork's Avatar
how do you get them over the needle with out takin the needle off? Is the hole big enough that it slips over? Also any shots of them at night wtih just white bulbs behind them?
Old Apr 26, 2002 | 05:34 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
I have a set of the silver overlays and they are very easy to puton and the instructions tell you exactly how to do it...plus it gives you a chance to clean up in there
Old Apr 28, 2002 | 12:20 AM
Car: '89 Trans AM
The needles that I am referring to are the far left ones on an 89 T/A. Look at the bottom pic from the link, it shows the gauges that you have to remove the needle. The pic is on the bottom.
http://members.aol.com/rmacewen1/index.html
Old Apr 28, 2002 | 07:04 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
how do those whitefaced gauges look at night? can you see all of your gauges clearly?
Old Apr 28, 2002 | 11:26 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
those look pretty good. how hard to install.
Old Apr 28, 2002 | 02:23 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Old Apr 28, 2002 | 06:59 PM
Car: '89 Trans AM
86FyrBrd, did you have the volt/fuel and oil pressure/temp overlays cut or were they whole when you put them on. Those are the ones that you have to remove needles on.
Old Apr 28, 2002 | 08:58 PM
86FyrBrd's Avatar
I cut mine, looks fine!
Bubbajones_ya
Jul 6, 2024 08:32 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
