carb swap
Old May 15, 2001 | 04:15 PM
AirN1's Avatar
carb swap
i bought a edelbrock 600 elec. choke to replace my old q-jet elec. choke on my 84 t/a....there are two electrical plug ins for i dont know what on the old q-jet but there arent any on the edelbrock.....what should i do? what are the wires for? do i need them?
if they are emmisions stuff...i went with a non emmisions carb....since im taking all my emmisions off anyways....
ty in advance
Old May 15, 2001 | 04:38 PM
Jester's Avatar
I would assume those are for some computer controled gizmo, maybe one is the choke. To do that swap..you'll also need a non computer controlled distributer tho.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 15, 2001 | 09:01 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
No you don't need them they are for the comp. I am assuming you swapped the dist. too.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old May 16, 2001 | 11:10 AM
zee28's Avatar
Car: 86 iroc
you will have to swap the distributor to.and some say you will get a check engine light ,others say no.
~mike~86 IROC-Z
Old May 16, 2001 | 07:02 PM
AirN1's Avatar
so what if i just remove the computer? will it make things easier??
Old May 16, 2001 | 10:07 PM
Cosmik Debris's Avatar
The computer in an 84 controls three things. The fuel mixture solenoid on the carb, the timing advance and the lockup of the torque convertor. The carb you have taken care of. You need a vacuum advance distributer and either a kit for your tranny or a simple sitch to lock the convertor.
Old May 17, 2001 | 12:09 PM
AirN1's Avatar
k guys thanks....now to get the computer out.....heres where i get lost lol
Old May 17, 2001 | 02:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Leave the computer in there. It doesn't hurt anything, doesn't weigh that much. Disconnect what you don't use (carb TPS & MCS, 4-wire distributor connector), hook up what you need (choke thermostat, power wire to distributor, TCC lockup switch). Just leave everything else alone and save yourself some other headaches.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/94.6 @ 5800' Bandimere.
Old May 17, 2001 | 02:18 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
If it helps all the computer wiring comes from the passenger side. All your gauges and actual important wires are from the driver's side harness.
Old May 22, 2001 | 01:26 AM
84ST.sleeper's Avatar
I am about to do the same thing. I have a Edelbrock 1405 and performer intake along with a non-computer controlled distributor from a older chevy. My 2 questions are:
1. Will the computer still lock up the converter after I have removed the CC Q-jet?
2. Does it matter if my new distributor is not a vaccume advance unit if so what are the drawbacks of it not having the advance a can.
Thanks for the help in advance!!!!!
Old May 22, 2001 | 08:48 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
<font face="Verdana, Arial" size="2">Originally posted by Karps TA:
If it helps all the computer wiring comes from the passenger side. All your gauges and actual important wires are from the driver's side harness.</font>
Be careful with this. I don't know about the LG4 or the L69 but the cross-fire motors the oil pressure wire goes by the comp not through it but around it.
future mods:
Old May 22, 2001 | 10:12 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
<font face="Verdana, Arial" size="2">Originally posted by 84ST.sleeper:
</font>
To answer in order,
1. Your Torque Converter lockup will not work without the CC-carb, because the Throttle Position Sensor will not be present. The TC uses this. There's kits available to remedy this.
2. Your CC-distributor will have no advance without the CC-carb, once again because it uses the TPS on the carb.
Usually when you bypass the computer system with these components, you'll get a Check Engine light because the computer is programmed to tell you when there's no references returning from the dist. Although, I have seen one car where the computer basically just shut down when this was performed; but I guess stranger things have happened.
DR Stevens
1984 Trans Am 305HO L69
1991 Firebird 305 L03
[This message has been edited by eightTfourTA (edited May 22, 2001).]
Old May 25, 2001 | 08:18 PM
AirN1's Avatar
so basically i need a vacum advance distributor and a kit for the lock-up? and i can just leave the comp in there but not hook anyhting up...correct?
Old Jun 1, 2001 | 02:33 PM
Matt's Avatar
what if you have a stick shift? I plan on doing this swap also.
Matt
Old Jun 5, 2001 | 04:31 PM
jrr's Avatar
jrr
I've done the swap and I should've done this years ago!
I did my first de-computerization of my ghetto-cruiser 1984 Olds 88. It now has an older (1972 Olds) Q-Jet and HEI distributor from a '78 403 TransAm. After I did the usual tweaking and fine tuning, that Olds will snap your neck on takeoff (no EGR, either!).
The smog pump runs full time to the cat converter now, the evap cannister is still working, the exhaust heat riser valve still works, but the TCC doesn't work. Go to the JEGS website. JEGS has a TCC lockup switch kit for non-CCC cars using the TH200-4R and TH700 overdrive transmissions.
So, go for it! That CCC stuff is just cluttering up your car anyway! :-D
Old Jun 6, 2001 | 03:07 AM
EvilCartman's Avatar
Car: '82 Z28
<font face="Verdana, Arial" size="2">Originally posted by eightTfourTA:
To answer in order,
</font>
Hehe, something must be wrong with my car then. I'm running a Holley and a vacuum adv. distributor and the 200C still locks up in 3rd. The computer is still connected but I'm going to unplug it tomorrow to see what happens.
Now, when I unplug that ECM, shouldn't the check engine light go out? it doesn't on mine. A friend of mine asked if the car would start with the computer out, showed him it could, and that's how I found out the engine light stays on. ('82 Z28)
Old Jun 6, 2001 | 03:14 AM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by super83Z:
Be careful with this. I don't know about the LG4 or the L69 but the cross-fire motors the oil pressure wire goes by the comp ...
</font>
<font face="Verdana, Arial" size="2">Originally posted by Matt:
</font>
In my 86Z the back up lights went through the computer, nothing else of importance
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
