RPM gauge stuck
Old Jun 1, 2004 | 01:15 PM
2camaros1kid's Avatar
Car: 89 camaro RS and 90 camaro IROC Z
Engine: 2.8MPFI V-6 and 350TPI 5.7 liter V
RPM gauge stuck
in my 90 iroc the rpm gauge is stuck! every time it turns on the gauge goes all the way up and stays until i turn it off! the engine runs fine so whats goin on????????
Old Jun 1, 2004 | 01:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's broke. At least, that's the technical term for it.
Old Jun 1, 2004 | 03:42 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Where does the needle sit when the car is turned off? Is it like 5000 or higher?
When you turn the key to the 'run' position - before starting - does it go around clockwise until it pins?
If so, I can tell you how to fix it, and it isn't difficult.
Old Jun 1, 2004 | 10:23 PM
stevecvash's Avatar
Car: 85' Camaro Sport Coupe
Engine: 1970 LT1
Transmission: 700-R4
Axle/Gears: 3.23 Posi
lift your foot up off the gas j/k but seriously im having a similar problem, when i go to turn it over the tach just jumps all the way up past the 7000 mark and stops b/c of the stud and stays there until i turn it off i just cant seem to figure it out
Old Jun 2, 2004 | 12:15 AM
If the tach needle sits at 5000 or higher with the key off, and then pins at over 7000 when the key is turned on, this will work.
Remove the front bezel - 8 T15 torx screws
Remove the clear plastic lens - I forget how many and what size/type of screws.
Use your finger to turn the needle back down to the 0 to 1500 mark.
Test it, then re-install the lens and bezel.
Fixed
If the needle sits down near the 1000 mark with the key off, and pins when the key is turned on, you have problems elsewhere.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
