Trunk Alignment
Old Oct 29, 2002 | 03:08 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Trunk Alignment
How do you align the trunk so when it closes the rear spoiler on the trunk hatch lines up with the two spoiler ends on the rear fenders?
1991 Camaro RS w/V8 TBI
Old Oct 29, 2002 | 03:49 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
If its a matter of up/down adjustment, there are rubber pieces that screw in/out on the hatch to adjust it. If its a matter of in/out adjustment, there's a tech article on this site.
Andy Fanshawe's Avatar
Car: 91 camaro rs
Remove the plastic panel at the rear of the headliner and you will see 4 nuts holding the hatch down. The 2 on the passenger side go through elongated holes and they can be loosened and the hatch moved. Unhook the gas struts first though, since they wiil want to push the hatch backwards. I had to remove the hatch completely to file out the 2 drivers side holes to get enough movement to line it all up. If you do that, make up some new gaskets to seal the hatch hinges down to the body otherwise water will drip in.
Good luck.
Andy.
Old Nov 1, 2002 | 07:48 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Make sure you don't overtighten the bolts on the hatch. The first pot hole or the first time you slam the hatch, the rear window will shatter.
Old Dec 29, 2002 | 10:47 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
good thing you told us that because i was about to align my hatch and i would have tightend it alot then probably slammed it in my joy of accomplishment. not knowing that i would be looking at glass all over my car afterwards!
cheers!
Old Dec 29, 2002 | 11:35 PM
MdFormula350's Avatar
yeah dont need broken glass all over the place it would be a mess...
Ed1LE
Sep 30, 2018 09:14 AM
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
