Blower Motor Problem
Old Sep 14, 2001 | 05:14 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
My blower motor for my air conditioner doesn't work in my 1988 IROC. I checked the fuse panel and all the fuses are fine. When I start the engine and turn on the A/C, the A/C compressor clutch engages but no air comes through the vents due to a dead fan. The connections on the blower motor are conected and no wiring harnesses appear damaged.
I checked out both Chilton's and Haynes shop manuals and looked at the electrical wiring schematics. The Chilton's shop manual indicates that there is a blower motor relay. Where is this relay? I can't seem to find it. I do know where the fan, fuel pump, and MAF burn off relays are.
What else could be the cause of my blower motor not working?
Old Sep 14, 2001 | 05:25 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Jump 12+ volts from the battery to the purple wire on the fan to make sure the fan motor isn't smoked 1st.
The mind is like a parachute, it only works when its open
Old Sep 17, 2001 | 06:58 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Thanks for the advice. The blower motor is working fine again. I guess my IROC didn't feel like being tested so it started working fine again.
Old Sep 17, 2001 | 07:04 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
