Tubular or boxed LCA?
Old Jan 27, 2003 | 09:36 PM
IROC-Z4ever's Avatar
Car: 1986 IROC
Transmission: TH700r4
Okay I would think that boxed might have more strength but is it really worth it to get them? I am going to start taking the car to the drag strip. And i am planning on doing a LT-1 Conversion (maybe convert that to LT-4) with in this year, so would it be better to get boxed?
Also, what would you recommend for LCAs? BMR or Spohn? My friend says that BMR is good but all I see here mostly is to go with Spohn.
Marty
Old Jan 27, 2003 | 10:27 PM
Kandied91z's Avatar
i love my kenny browns.....this is a primarily spohn site. hence the sponsorship.
the reason i like mine more is in the overall design and less vibration....cheaper as well.
if you can spring for the tubular that's the way to go.
Old Jan 27, 2003 | 10:53 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Where do you buy Kenny Brown LCA's?
Old Jan 27, 2003 | 10:58 PM
BORLAZ06's Avatar
I would think boxed would be stronger but I think its all on design and material. I personally like tubular cuz its lighter and it looks nicer than boxed. I have Spohn LCAs and they hold up well. I hear nothing but good news bout BMR.
Old Jan 27, 2003 | 11:04 PM
Chet's Avatar
Car: GTA
You can find kenny brown stuff here:
http://www.kennybrown.com/home.html
Old Jan 28, 2003 | 04:35 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
KB stuff is nice, but seems a little pricey for what it is.
Old Jan 29, 2003 | 01:35 AM
Kandied91z's Avatar
part for part KB is the exact same thing except the end that mounts to the body uses a different type of bushing that is more quiet.
i agree with supporting steve since his products are competatively priced and he seems to be very knowledgable. there are other things out there though.
when i bought mine steve didn't have any of those items, strictly the boxed setup. KB was one of the first to offer the tubular let alone a 2 way adjustable. i love mine, that's all i can tell you. either way i don't think you'll go wrong.
Old Jan 29, 2003 | 08:20 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks for the info guys. Now I just need to make a decision!
Eric
Old Jan 30, 2003 | 07:29 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Rectangular is more suited to drag racing. They are stronger than tubular and can put down the power (from the weight transfer) better than an equally built/designed tubular bar. Although, they do not flex, causing binding in the rear suspension.
Tubular is more suited to street/Auto-X/Road Racing. They are more flexible and better suited for cars that will take turns aggressively. They flex upon weight transfer more than a comparable rectangular bar. Since they allow flexability, they will not bind when taking corners hard.
My SS has a drag race setup, so it will have rectangular suspension pieces.
My Z28 will be for road racing, so it will have all tubular suspension.
Old Jan 31, 2003 | 12:30 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
I like my spohn adjustable lcas, throw on some of steves realocation brackets and you will able to see a big difference.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
