E-Brake cable 10164125 ???
Old Apr 15, 2004 | 01:26 PM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
Transmission: 6 speed
Axle/Gears: Strange 12 bolt 3.73
I cant find one anywhere GM says they are discontinued and I need them for my rear disc conversion. Any help would be great thanks
Old Apr 15, 2004 | 02:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Aftermarket ones should be available.
Old Apr 15, 2004 | 10:17 PM
ebmiller88's Avatar
Hmmmm...it worked on GMPD
www.gmpartsdirect.com
$15.83.
I get mine from Dal for $17 but he's less on shipping. I hear Auto Zone carries them but I like to stay with GM stuff here.
Ed
Old Apr 16, 2004 | 12:42 AM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
Who is DAL ?
I placed a big order from GM parts direct and they got back to me saying the part was discontinued.
Old Apr 16, 2004 | 07:34 AM
ebmiller88's Avatar
Dal Slabaugh
Van Devere Olds-Pont
877-448-5451
His direct line, best parts guy I've dealt with. Trust me, they are available. I have 4 in my shop.
Ed
Old May 10, 2004 | 03:25 PM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
Ed
Tried to order one from Dal and he tried for 3 weeks to get one there are none left in the country and they are discontinued from GM
Anyone know if they are avaliable aftermarket
Old May 10, 2004 | 05:38 PM
ebmiller88's Avatar
Well that sucks...word is that Auto Zone has them.
Ed
Old May 10, 2004 | 06:34 PM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
Yeah now i am stuck i tried autozones website no listing shown. I wonder if i could find some in a junk yard doubtful
Old May 11, 2004 | 10:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I purchased from CarQuest, 89-92 1st design (I think these are the 1434mm).
JamesC
Old May 11, 2004 | 11:10 AM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
Called carquest in Texas they have no listing. Do you have a brand name or a part number?
Old May 11, 2004 | 11:14 AM
ebmiller88's Avatar
I just ordered a pair from GMPD as they still showed them available so we'll see what happens.
Ed
Old May 11, 2004 | 12:29 PM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
I did the same thing a month ago within about 48 hours you will get a email returned to you saying the part has been discontinued.
Old May 11, 2004 | 01:24 PM
ebmiller88's Avatar
OK, thanks for the heads up.
Ed
Old May 11, 2004 | 04:06 PM
JamesC's Avatar
I believe Ed confirmed on an old post that the 10164125 is the 1434 mm cable (1st design according to CarQuest). I ordered the latter from CarQuest under part # BRK 8788. I haven't yet installed, however.
Ed?
Here we go: https://www.thirdgen.org/techbb2/sho...ghlight=1434mm
JamesC
Old May 11, 2004 | 08:11 PM
larryz28's Avatar
Car: 82 Z28
I just put new E cables on both sides. I got after market ones. They were in stock. They do have two different numbers for the cables. I have an 82 Z. the number I think you used is for the drivers side. Mine were $19 each. Auto Zone had them but it would take two to three days for them to come in. I went to a local shop and got them the next day. Hope this helps.
Old May 12, 2004 | 08:28 AM
ebmiller88's Avatar
Yes, James, that's right...thanks for the link. I always forget what I posted a while back...damn beer...
Ed
Old May 12, 2004 | 02:00 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
i believe napa carries ebrake cables as well. i'm checking right now for part numbers.
i looked up a 1991 camaro with 4 wheel disc brakes on napaonline.com
NAPA United Parking Brake Cable - Rear
Usually ships within 3 to 5 days.
UBP 94264 $ 19.69 1st Design, 1434mm
UBP 94597 $ 21.49 2nd Design, 1460mm
your local napa should be able to have these within 3-5 days (possibly overnight) if they don't have them in stock.
to my knowledge, these UBP cables should carry a lifetime warranty on them as well.
Old May 12, 2004 | 03:22 PM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
Found some at O'Reiley auto parts in TX they are under the Brake Best line and have a part #BC94264 they were special order and sell for 15.99 I should have them next week hopefully they will work
Old May 13, 2004 | 07:32 AM
ebmiller88's Avatar
Confirmed:
From GMPD:
10164125 CABLE ASM 4.779 15.83
Comments: 3, 17253, CANCELLED NO STOCK OR S PRINT
****IMPORTANT UPDATE**** of your order number 78xxx:
Part Number 10164125: Cancelled (cancelled no stock or sprint) Please go to http://www.gmpartsdirect.com/login.c...on=orderstatus and login with your e-mail address and password. In the top right hand corner click on the order history button, then click the order you want to view. At this point you will be able to click on the tracking number to view your orders progress to you.
Aftermarket only now...
Ed
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
