GTA wheels... front and rear different.. how?
Old Oct 15, 2001 | 03:21 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
Well theres a story to why, but I dont think anyone is interested, soo.. I need new wheels for the right side. I found used ones from a site ( http://www.tacreationsusa.com/firebird.htm ) and the price was $150 front and $100 rear. I noticed today that my front wheel is set in further than the rear (left side wheels). Is this the reason for higher pricing?
Why are the wheels like this anyone know?
Thanx
<A HREF="http://albums.photopoint.com/j/View?u=1670288&a=13155057&p=47834932&Sequence=0&res=high" TARGET=_blank>1988 2.8L MPFI auto Camaro
</A> (bright red, not pink)
67 Camaro, being rebuilt. 383 6-71 blown etc etc
1988 5.7L GTA ---GTA's interior
Old Oct 15, 2001 | 07:38 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
<font face="Verdana, Arial" size="2">Originally posted by 67 Camaro 88:
Thanx
</font>
The rear axle is wider than the front, so a different offset wheel was necessary. If you put the rears on the front, they'll contact either the spindles or the caliper, I forget which. You can put the fronts on the rear without any problems, but if you lower the car, it could be necessary to roll the inner fender for additional clearance.
The fronts probably cost more because they are more popular. Most accidents occur in the front of the car, plus many people buy 4 fronts for non-fbody applications.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 15, 2001 | 08:12 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am running a set of 4 fronts on my Formula right now, and it looks just a little more agressive than my all stock Formula. I paid $50 for te set of 4 fronts, and I am planning on refinishing mine soon. Its funny, you could walk around the car 5 times, and no one would ever notice, the rears are more flush with the fender, than stock. Of course the Baer Brakes in the front help my front wheels look to be about 1/2" more on each side does not hurt, so it looks balanced.
The question you asked, what the difference is? The fronts have about a 3/4 of an inch more of an offset than the rears.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro
83 T/A
http://www.3rdgenformula.com
Old Oct 15, 2001 | 08:39 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is my car with 4 front GTA Wheels.
WS6 Trans Am.
View My Ride @ thirdgen.org
[This message has been edited by Zepher (edited October 15, 2001).]
Old Oct 15, 2001 | 02:54 PM
Car: Camaro
Engine: 3800
I like the look of 4 fronts... Hmm... wish I could find two more hehe...
Glad they didnt make it too deep in the front, may give off a front wheel drive look... that would not be good.
Thanx for the replies btw Get the wheels back from the shop Monday cant wait
Old Oct 16, 2001 | 05:06 PM
toosloz's Avatar
classic industries sells them for 140 a pop, the difference is the offsets....16 mm front and 0mm offset rear
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
http://www.geocities.com/toosloz/84camaroz28.html
Old Oct 18, 2001 | 06:54 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
You have it backwards the
front offset is 0mm and the
rear offset is 16mm
Old Oct 21, 2001 | 08:38 PM
Car: Camaro
Engine: 3800
Got them straightened at a shop here for 130... not too bad, heh. Thanx for the replies tho
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
Nov 16, 2015 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
MORREALE5
Sep 13, 2015 09:16 PM
