hatch motor help.
Car: 92 Z28
Engine: Boosted LSX
hatch motor help.
I'm looking for diagrams for the following.
91Z28 hatch motor
and
91 RS vert hatch motor.
I know someone who had a broke 91Z motor and out in a complete unit form a 91 RS VERT but 1 or 2 wires are diff.
or 1 wire with 2 prongs and her car is 1 wire 1 prong i forget.
If I rem right the motor goes down put wont stop. I know it worked fine when pulled out of my vert. and put in in a locker in my shop.
any help would be great.
THANKS
Chris
91Z28 hatch motor
and
THANKS
Chris
Axle/Gears: 3.45, 3.27, 3.27
Re: hatch motor help.
Originally posted by TPl383
If I rem right the motor goes down put wont stop....
Chris
Chris
There were two styles of motorized hatch pull-down unit used in 1991. Ealry ones have a metal frame. Mid-year they changed to one that has a tan-colored plastic frame to it. Both use the same gear nut. A broken gear nut will cause the same problem for either design.
Lon Salgren
Top-Down Solutions
Car: 92 Z28
Engine: Boosted LSX
Lon,
thanks. I spend about an Hour searching after I posted this and found some good info from you befor. my 1st search didnt come up with anything. Reworded it and WOW you posted the info quite a bit.
Got a link to the gear?
THANKS.
THANKS.
Car: 91 Camaro Z28
Engine: 350 L98 TPI
Axle/Gears: 3.23 posi
Trickster
Can you send me those schematics also. Having trouble with my hatch too...though not the same.
https://www.thirdgen.org/techbb2/sho...hreadid=286389
Car: 91 Camaro Z28
Engine: 350 L98 TPI
Got it thanks Trickster...now if I can figure it out
what I really need to do is get power straight to the motor to make sure it works and if it does then I need to figure out which switch is bad.
You can supply +/-12v directly to the motor by using test probes. There are two small holes where the reversing switch attaches to the terminals on the motor.
Lon
Lon
When you are putting the hatch motor back in, make sure its exactly where it was, if its over to the side too much, the hatch will come down on the side and i took 2 big chips out of my paint.
