More Pictures of Boxed Lower Control Arms
Old Apr 1, 2001 | 03:37 PM
Steves ZZ5's Avatar
Just thought I'd follow up on the Boxed LCA's post.
After welding the .125 steel stock onto the LCA's, I took the finished pieces to work and sandblasted them. Then I threw on a coat of enamel rust preventative primer followed by a couple coats of Rust-Oleum #7777 Satin Black spraypaint. For more imformation, check out the previous post at: https://www.thirdgen.org/messgboard/...ML/001422.html
Here are the finished pieces before installing new bushings. For the pictures prior to paint, check out that link I included above.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
[This message has been edited by Steves ZZ5 (edited April 01, 2001).]
Old Apr 1, 2001 | 08:10 PM
Fred85TA
Guest
Posts: n/a
If I wanted to box my LCAs, where would I get the steel? Is it just scrap or do I go buy it especially for that? Thanks in advance.
Old Apr 1, 2001 | 09:37 PM
Steves ZZ5's Avatar
As far as metal, all you will need is scrap .125" (1/8") steel. You don't need anything more than scrap carbon steel, and it doesn't need to be hardened or anything like that.
The Road Warrior
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
BikeFarm
Aug 11, 2015 11:35 PM
