to those who have koni adjustable shocks...
Old Nov 21, 2001 | 02:35 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
how do u adjust the rear shocks? what tool do u use? i have the little cap lookin tool for the struts, but i'm confused about the rear shocks
TIA
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Nov 21, 2001 | 09:52 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
O.K.-
Unbolt the back shocks at the rear end. Next, pull down the plastic sleeve around the shock tube. There is a button you depress on the top of the resevior tube (large) turn the bottom of the shock left or right, you should feel it click; these are the settings. There should be three settings. Oncethere, release. Hope this helps.
<font face="Verdana, Arial" size="2">Originally posted by fly89gta:
TIA
</font>
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Old Nov 21, 2001 | 10:17 PM
Rick89IROC's Avatar
What irocdaddy said, plus turn clockwise for firmer, and counter clockwise for softer. Full range from soft to firm is just 1/2 a turn. If the button doesn't pop back up after you are done, wiggle the shock back and forth just a little until the button pops back up.
Rick89IROC
Black 89 IROC-Z Convertible 305 TPI
13.95 @ 102.18
DGGM 95 Impala SS
13.69 @ 101.70
Old Nov 22, 2001 | 07:54 AM
fly89gta's Avatar
Car: 2018 Camaro SS
thanks guys!
and Rick, bad *** car!!!
Old Nov 23, 2009 | 08:16 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Re: to those who have koni adjustable shocks...
do the shocks need to be fully removed from the car? Or do the bottom bolts just need to be removed?
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
