What tires for Iroc 16" wheels
Old Sep 1, 2005 | 12:07 PM
Torqjunki's Avatar
Car: 1989 Iroc
Engine: Cammed LS3
Transmission: 4l80e
Axle/Gears: 4.10
Will a 255/50/16 fit my 85 Iroc without issues on the stock wheels? Looking at the Kumho Supra 712. Thanks
Old Sep 1, 2005 | 08:03 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
yes
Old Sep 1, 2005 | 10:32 PM
ckeene502's Avatar
yes
Old Sep 4, 2005 | 09:49 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
I run 245/50 R16s on the front and 255/50 R16s on the rear
Old Sep 8, 2005 | 09:29 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
255s on the front will rub on some vehicles, thats way walter has a good combo 245s on the front and 255s on the back.
Old Sep 8, 2005 | 11:04 PM
The Wizard's Avatar
Car: '85 Z28
Me too, fits fine.....
Old Sep 8, 2005 | 11:44 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I've got the Kuhmos, and I like them a lot. Look good, bite hard once they warm up, and never squeal unless they're low on air. Had a knot pop up on one sidewall though and had to replace that tire.
I suckered out and put the 255s on the back. The 255s are noticably taller than the 245s that I have on the front, and rake the *** of the car just a bit, which I personally dislike. Taller tires also take a little bit of your rear gear ratio away too, which, in most cases will slow acceleration just a tad.
Realize that the Kuhmos are directional tires so when you rotate them, you'll have to break them down off the wheels and swap them side to side. With wider tires on back, you won't be able to rotate them front to rear as well.
Next time, I'll put 245s all around.
Just my .02
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
