Vette aluminum heads on a 305 tpi?
Old Aug 25, 2001 | 10:37 AM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
Could corvette aluminum heads be put on a 305 tpi car. I have a 91 z28 with a 305 tpi and i want to put some vette aluminum heads on but i dont know if i can or if that would work or if it would make my car slower or faster or what? I just need some imput thanks.
Old Aug 25, 2001 | 11:24 AM
vortech305's Avatar
i actually have vette alluminum heads on my 305 TPI, make sure u get the alluminum heads from a 87 to 91' corvette, In many publications they say that the corvette heads works 1 1/2 times better on a 305 than 350. I paid $350.00 for my vette heads which were rebuild and another $300.00 for the porting and polishing, defenetly worth it.
Old Aug 25, 2001 | 01:16 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
They will work better than L98 heads because they have a 60 cc combustion chamber and won't lower your compression ratio like a cast iron L98 head will. But remember, vette heads, even 87-91 did NOT change the angle on the four intake bolt holes in the center. So you'll have to get the holes inlarged on you intake to make them match. Also, corvette heads run the EGR differently, and they have a raised exhaust port which could possibly cause problems sealing to the manifolds. But don't misunderstand; they're a great head if you are willing to make them work.
91 Z28
Come see The Vicious...
Old Aug 25, 2001 | 01:24 PM
vortech305, did you have any trouble puttin the heads on or was it a nice bolt in thing? I definatly think its time for new heads cause the stock 305 heads are not the best. I have headman headers and i wana know if you think those will bolt up to the vette aluminum heads? Thanks a lot
Old Aug 25, 2001 | 02:06 PM
vortech305's Avatar
im not too familiar with heddman but i have edelbrock headers and they fit fine, all u need is some know how's and elbrow grease and ull be fine.
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
