Is there ANY way to make the IROC-Z hood louvers functional????
Old Mar 22, 2001 | 10:00 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Has any1 done this, and is it possible to do?? It would get more air in there. Thanks!!
Looking For:
87 IROC-Z28 350 TPI: The car I want.
84 TRANS AM 305 H.O.: Another car that would be OK to own while I look for the IROC-Z!!
[This message has been edited by IROCZTWENTYGR8 (edited March 22, 2001).]
Old Mar 23, 2001 | 12:19 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
My answer to you might not apply because I own a Pontiac. I'm not sure how the louvers are attached. Anyway, I guess that depends on how much metal working experience you have. I'm an aircraft metal smith in the Navy and I could make louvers out of aluminum that look exactly like the stock ones and are functional. Of course, that's a lot of work for something like that. I would suggest cutting the hood out underneath the louvers(provided you don't cut out any structual material) with a cutting wheel and a straight grinder. Be sure to leave the areas where the louvers attach in tact. Then, modify the louver inserts by drilling in between the louvers and using a half round file to clean up any left-overs. As I said, I have no idea, how those things attach. I'm just guessing. Good luck!
'89 Firebird Formula-
K&N Air Filter, Holley Throttle Body Air Foil, Hotchkis Strut Tower Brace, Hotchkis Panhard Rod, Hotchkis Trailing Arms, Kenny Brown Subframe Connectors, GT Auto Assesories aero wing
Old Mar 23, 2001 | 12:22 AM
Engine: 5.7L TPI
Almost forgot to tell you. I opened the turbo style hood I have on my Formula by removing the insert and replacing it with a piece I made that has a hole in the center to which I attached a piece of aluminum screen. Looks nice.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
PestilenceIV
Aug 20, 2015 02:33 AM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
