1LE AC Delete pulley...
Old Feb 7, 2003 | 08:04 PM
BretD 88GTA's Avatar
Car: Yes...
Transmission: See "Engine"...
I have two part numbers for the AC delete pulley:
1) 10115875 which is what is listed at www.1le.net for a 3rd gen.
2) 10055890
Both part numbers come up as valid and as a "Water Pumop Pulley" at www.gmpartsdirect.com
However, I have pics of each and there are some differences. See for yourself below:
From what I can gather, it looks like either one will work. Does anyone have any more info. on this?
Old Feb 7, 2003 | 10:17 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
That is very strange Bret, the pulley diameters are obviously differant , and the brackets themselves are differant, but why? Seems as though GM would make up tooling for the bracket and be done with it, but to make another is odd. The picture on the bottom (your post) is the same as I just bought. Never seen the one above before.
Old Feb 7, 2003 | 10:19 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Actually, looking closer, I wonder if it is possible that the above pulley was weak, and they had to revise the design...? Look close at each of them, the lower looks to be much stronger. Think it is even an issue?
Old Feb 7, 2003 | 10:28 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
You sure the top one isn't for a v-belt setup?
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Maybe the top pic is for LT1s????
The bottom pic is definitely used on third gens.
Old Feb 7, 2003 | 11:23 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
the bottom pic is the pulley that i have on my camaro
Old Feb 8, 2003 | 12:53 AM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
same here.. bottom one.. I believe the part number was the 10055890 .. sounds familiar (I did lots and lots of searches, typing the number many times) ... not sure about the other.. isn't there a 1LE 4th gen too? maybe that IS the 4th gen one.... who knows.
Old Feb 8, 2003 | 12:58 AM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
Ah correct me if i'm wrong but isnt the top pully the one used for ......smog delete......on serpentine belt setups........I had done the search also for myself for when I do the ac delete and the bottom pully is for 3rd gen cars.....
Old Feb 8, 2003 | 01:05 AM
Car: 91 Firebird
Transmission: A4
could be... if I remember correctly the smog pulley was smaller than the a/c pulley.... but I just ripped that off and bypassed it, so I wouldn't know for sure.
Old Feb 9, 2003 | 01:34 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The top one is an LT1 A/C Delete Pulley, and it is listed as Smog or Waterpump Pulley for some reason.
Here is a picture of mine with the part number showing on it,
Old Feb 26, 2004 | 08:59 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Same setup I am using in my 94....I'm working on pulling the a/c compresser out with the engine in the car. The front 3 bolts were cake to remove. the bottom back bolt was as easy. But I have tried everything to get on the top back bolt..any suggestions ? do I need to remove any acc. Alt....or anything that would make access easier? Any help would be great......
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
